E85 headlights
E85 headlights
Hi all,new member here,I've recently bought a 2005 z4 with a little 4 pot,love the car but I've a few questions to ask please, has anybody heard about the headlight control unit causing elec faults??
- enuff_zed
E85 headlights
Welcome to the forum.
We'd love to see photos of your new car too.
What exactly do you mean by faults? There are two bulbs in the front indicator unit and there have been occurrences where a failure in the Light Control Module (LCM) can cause one of these to stay on all the time.
A replacement LCM can cure this but unless you can find someone to re-code it you will get a tamper dot to show it is not the original.
Let us know more precisely what your issue is.
E85 headlights
Thanks for your reply,the fault started with only the headlights not working when switched on,only the side lights worked,if however I removed the large 40 amp fuse and replaced it immediately the headlights would work,also the instrument cluster will sometimes remain on even with the lights off,and my main beam and indicator warning light on the dash doesn't work
- enuff_zed
E85 headlights
Hmmm I would suspect the LCM yes. But not a fault I've personally heard of. But if it's all to do with lights then that is your starting point.Jalex wrote: ↑Wed Apr 05, 2023 6:31 pm Thanks for your reply,the fault started with only the headlights not working when switched on,only the side lights worked,if however I removed the large 40 amp fuse and replaced it immediately the headlights would work,also the instrument cluster will sometimes remain on even with the lights off,and my main beam and indicator warning light on the dash doesn't work
Don't suppose you're near me at all? I have a spare LCM you could slave in to see if it fixes it before you spend out on one.
E85 headlights
Thanks again for getting back to me so soon,I'm in the east mids,where are you??
- enuff_zed
E85 headlights
Attleborough, Norfolk.
But bigwinn is in Lincoln and may be able to help. He should see that I've referenced him in this post.
E85 headlights
Thanks,how could I get in touch with him??
Onlinebigwinn
E85 headlights
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
E85 headlights
Hi bigwinn,how do I pm? New to this
- enuff_zed
E85 headlights
Click on his name in the left side and select reply in pm
