Coming back from first serious potter with CherryM I ran into a submerged pot hole with an all mighty bang on Sunday…
Limped home and after taking the front wheel off discovered dent in inside rim..what a 326M would have done in the situation who knows..
I’m down at a wheel doctor https://www.alloyfix.co.uk/ in Newcastle seeing if he can true them out…
Took the rear off just in case, turns out it’s even worse dent…
Bent two of my Apex Arc 8s..at the wheel doctor now..
- B21
- IMG_7582.jpeg (174.27 KiB) Viewed 620 times
- IMG_7581.jpeg (217.97 KiB) Viewed 620 times
A very modified Atacama Yellow 35is Previously a slightly less modified Atacama Yellow 20i MSport
OnlineWorcester_spoon
Ouch. Fingers crossed it hasn't fubared any of your suspension, but I suspect geometry might be out now?
03 Z4R 3.0i/Silver/custom quad/330d brake upgrade/LSD/G-Power supercharger/FIC 365cc injectors/Severn Tuning map
- B21
Good point…I’ll check..my exotic alignment guy is some distance away ..but I’ll bring that forward as he’ll be fitting my uprated RTABs etcWorcester_spoon wrote: ↑Fri Apr 28, 2023 11:12 am Ouch. Fingers crossed it hasn't fubared any of your suspension, but I suspect geometry might be out now?
- B21
Wheel doctor diagnosed both front and rear badly bent..rear worse..managed to true them out ok..
£120 for a pair
https://youtu.be/KKrdRQaIZ_A
https://youtu.be/EdEM80FFWzA
Before and after …
FWIW he says biggest issue is raised speed humps going over with both wheels..places massive load on inside edge which bends because it’s unsupported…
£120 for a pair
Before and after …
OnlineMr Tidy
Ouch.
Lucky you checked the rear wheel as well, and I'm glad you've got them both round again.
I hope your route for next week doesn't include that road!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- B21
I just assumed the front wheel was a goner..but then thought the rear wheel followed the same track..glad I checked..
1,000 miles plus next week vibrating and oscillating away wouldn’t have been good…
I’ve made a mental note on that pothole…it’s a bad stretch of road frequented by many logging lorries..lesson learnt…
