Replacement of OEM Sat Nav with Garmin, retaining ‘pop-up’ functionality
- kis
Very admirable project! Great job!
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Z4Mariner
Thanks for info - especially on checking the diagnostics page in the Garmin ! I just finished sectioning my project box to ca. 32mm high, removing molded-in screw mounts, and checking circuit board fit (just about perfect size).
Z4Mariner
Minnesota, USA
2006 Z4 Coupe 3.0Si, Montego Blue, MT
Minnesota, USA
Found this on YouTube: https://www.youtube.com/watch?v=IJk3UWn1bYkMojito wrote: ↑Tue Jan 23, 2024 12:48 pm "Garmin 66 power. Turn off automatically" (hidden menu option from Diagnostics Page > Turn Off Automatically) should prevent the annoying problem of the unit doing that "it's off but not really off" sleep state thing, draining the battery to nothing. This was an issue with the previous generation where it was required to hold the power button, wait for the true "Turn off the device?" prompt, and then it was off. This appears to have been fixed in the 66."
Haven't tried it yet, but there is a whole hidden world of interesting Garmin sub menus, which includes 'turn off automatically'. Interesting to see what it actually does.....
E85 3.0i SE Sterling Grey, 2004
E89 20i SDrive M Sport - Mineral Grey - Sold
Thanks kis. One of those projects where I wondered why I had started it when screen was all in pieces, but it turned out well.
I had a play this morning and the 'hidden menus' are indeed there ... interesting to see just how many satellites gps had fixes on. I also found the 'turn off automatically' menu, but alas it was already enabled. Think this means you can only toggle the sleep function on/off, not set it to totally shut down. Still I don't find this an issue in practice.
Well done sorting the circuit board box.
Just realised I hadn't included a photo of the screen in reverse camera mode - below.
- IMG_7694.jpeg (117.23 KiB) Viewed 470 times
- B21
Great piece of engineering and lateral thinking
Thanks B21. I'm one of those people that just can't stand trailing wires, so for me a phone or Tomtom on a mount just doesn't look right.
From the minute I bought the car I was working on ideas for an up to date 'OEM' look solution . In my case that actually meant starting out with a retrofit of an OEM Sat Nav, before progressing to the Garmin set up. I know crazy
- B21
I’m with you on the trailing wires issue..they irritate me intensely…Mojito wrote: ↑Thu Jan 25, 2024 1:09 pm Thanks B21. I'm one of those people that just can't stand trailing wires, so for me a phone or Tomtom on a mount just doesn't look right.
The technical truism is that rate of product enhancement in these portable devices is so much faster than the built in versions.
You’ve squared the circle with your left field thinking
What a great project this is. Might consider this myself
I've just been reading your Atacarma Yellow build thread. Brilliant
- B21
Glad you appreciate it
- Z4Mariner
Mojito, I'm posting for a little help. Here's where I am in 'cloning' your cool mod:
> Garmin DriveSmart 66 ready; back-up camera arriving tomorrow
> Wiring extensions are finished and ready for fitting into project box
> All old "soft touch" finish has been carefully removed, and re-paint is underway
> BT adapter is in hand
> New Business CD Headunit arrived in good shape from UK
BUT I have a couple of hurdles left and am looking for help.
1) I foolishly paid little attention to preserving the rotational position of the stepper motor when I took apart the screen assembly. Do I need to precisely re-set the motor pinion-to-rack orientation ? I'm seeking confirmation that I don't need to worry. I hope the screen operates only upon motor steps from a zero point, with perhaps a slip clutch (or two ?) and needs no special orientation in re-assembly
2) My North American Garmin DriveSmart 66 came with a Garmin 12V power adapter and a cable that has an in-line "box" near the USB A connector end. The cable box is a receiver and/or antenna for HD and FM traffic information in NA. Further, the cable is supposed to connect into the Garmin-specific 12V adapter - it's not compatible with standard USB ports (which will force attempted PC sync). To use this cable I will need to cut-and-splice it to get it through the screen housing bushing. Did you have any USB cable issue ? Did you have to wire in a Garmin power adapter ?
Thanks for the inspiration . . . and thanks in advance for your help !
Z4Mariner
Minnesota, USA
Minnesota, USA
Looking good Z4Mariner and pleased to see you went for the full package with the reversing camera, really worth it.
Ah you've got me here - I didn't mark it either when I took it apart and can remember now puzzling the same question A couple of photos attached from when I was disassembling screen to help others see what we are talking about. I just lined the 'circular cut out stop' on the gear quadrant with the 'stop post' - one of photos shows this clearly. The quadrant only moves in one direction from here - can't remember whether screen is in closed or open position at this point - that worked perfectly on mine on switch on. I know I opened/closed screen by hand on reassembly to make sure it meshed over full travel. Think you're right motor works on steps from a zero point. Hope this helps.
Interesting - UK version doesnt have the 'inline box' in cable. I ran a 'piggy back connector' from an ignition switched fuse, terminated that in a standard car 12v socket and plugged the Garmin power adapter into that to avoid any potential issues with forced pc sync attempt. Conveniently that gave me a spare usb power outlet for my dash cam - the Garmin power adapter has 2 x USB outlets on it I'll post a detail on which fuse I piggy baked onto.
Keep me updated, great progress
Mojito
- IMG_6343.jpeg (122.6 KiB) Viewed 235 times
- IMG_6312.jpeg (113.82 KiB) Viewed 235 times
Can't find a note of which particular fuse I piggy backed onto, but installed the ignition switched supply when i first got my Z based on this link: viewtopic.php?p=1530361&hilit=piggyback+fuse#p1530361
- Z4Mariner
Progress Report on my clone of your project:
- Finished assembly of Project Box & wiring
- Garmin rests between ABS guides to locate it laterally & vertically in bezel
- Added final paint (black with matte clear) to Nav display parts & reassembled
- Cut & spliced Garmin USB power cable to pass through display module bushing (9 wires + shielding/ground). US Garmin DriveSmart 66 has a 'brick' in the cable, the Garmin cables aren't standard USB, and the right angle USB-C connector will not fit through the bushing.
- Tested cable in another vehicle; the Garmin functioned properly
- Side trip - I decided to replace my 12V ashtray power socket with a USB-A/-C power port
- Re-purposed 12V socket GROUND (earth) to use for new port and the Garmin power port. Since the original 12V circuit is 15A, two ports with 5A and 7.5A fuses should be able to share this ground on the conservative side. Removed 15A fuse in F5 and de-pinned power pin in ashtray connector for safety.
- Powered USB-A/-C port using 5A fused piggy-back tap on F8 (switched, ashtray LED).
- Powered Garmin adapter with 7.5A fused tap in F2 (switched, spare slot).
- Completed in-car connection of Nav display, project box, power cable, Business CD headunit, and even my MagSafe phone mount for a test before final installation.
- First power-up . . . . momentary “Uh-Oh !” . . . . I connected all except the project box with the SatNav circuit board !
- Second test . . . . Success !!
I should share that indeed the stepper motor and logic seem to self-index as I had hoped, so rotation of the stepper motor while out of the car was not an issue. I'll post again when I've completed the whole project.
Things left to do:
Securely install the project box / circuit board, re-install Nav display and Business CD Headunit, renew foam on vents and install, install the BlueBus BT I just received, and install the back-up camera.
Thanks for your pioneering and assistance, Mojito !
Things left to do:
- IMG_6360.JPG (166 KiB) Viewed 145 times
- IMG_6234.JPG (191.01 KiB) Viewed 145 times
Z4Mariner
Minnesota, USA
Minnesota, USA
Hi Z4Mariner and well done, some very neat work there Great to hear all working properly. Lovely finish on the Nav display repaint - as good as new
Thanks for sharing how you did things, really helpful for anyone else considering going down the same route. The abs guides to locate the screen are really neat. Also how you had to cut and splice the US spec Garmin 66 USB cable - fortunately for me, not necessary on UK spec USB cable.
Look forward to hearing all complete and seeing some photos of finished installation. Any comments/observations that might help others on Garmin 66 operation in this install appreciated
