Highbeams
Highbeams
I've got a 2003 e85. Highbeams work when I pull the lever towards the driver but don't come on when I push towards dash. Any solution to this?
- colb
Highbeams
I would take the stalk switch off and take a look at the contacts in there for the high beam and see whats going on with them, maybe dirty or out of alignment also explore the relay for the high beam on the fuse board, check that first before exploring the stalk switch.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
- BumpyZ4
Highbeams
Do you have Xenon headlights? If so, the "high beams" (which is a halogen H7 bulb) is only used for flash to pass. The actual high beam function is performed by the Xenon, as they do both the low and high beam function.
2003 E85 3.0i Sterling Gray
KLR 650
Diva Roadster (Kit Car)
KLR 650
Highbeams
Thanks I will check the stock switch and relay. Just bought the car so it may have a blown fuse or bad relay.
Highbeams
I'm having the same problem with my 2005 2.5i. In my case, the previous owner took out the OEM headlight assemblies and replaced them with OEMassive aftermarket assemblies and they weren't wired up quite right. However, I don't know if that's the reason the forward switch brights aren't working.Audiomegatron wrote: ↑Wed Aug 23, 2023 5:45 am I've got a 2003 e85. Highbeams work when I pull the lever towards the driver but don't come on when I push towards dash. Any solution to this?
I didn't know that there was a separate breaker for the forward (constant) brights vs the pull/momentary brights. Can somebody confirm this is actually the case?
Current: 2005 Z4 2.5i: first time to own a BMW and loving it!
Previous: 2018 Chevy Volt / 2004 Acura RSX Type S / 1989 Acura Intergra RS / 1982 Ford Escort / 1968 VW Bus
Highbeams
Seems that the previous owner has installed new headlights also and trying to figure out the same
Highbeams
Because I didn't have the original ones installed in my car, I didn't understand that the flash to pass function is a separate bulb/lens, a halogen H7, and that's all that bulb is used for. Putting the lever in constant position therefore won't do anything. In other words, there's nothing wrong with the stalk.
