‘04 BMW Z4 E85 dashboard lights
I have an ‘04 Z4 E85 and dashboard lights are on. I replaced the alternator and battery with factory specifications. Lights still on. I then replaced all the sensors associated with each dashboard light. Lights will not go off. Haven’t taken it to dealer yet but wanted to get ideas from anyone that may have had same issue. Thanks
- IMG_2252.jpeg (115.79 KiB) Viewed 320 times
Check the main battery cable and do a scan with a model-specific scanner ie Creator 310 viewtopic.php?t=13765
- enuff_zed
Did you rerally replace all three airbag modules???
If so, did you get them coded with the VIN and system time?
As above, randomly xhanging parts on these cars is an expensive hobby.
Get the codes read first.
My guess is you may see k-bus issues.
Any other problems? Windows messing about? Indicators work but no dash light?
