Petrol sloshing around noise?
Is this normal?
To be able to hear liquid (presumably petrol in the tank) sloshing around - behind the drivers seat
Seems to depend how full the tank is for me
I might have imagined it but seems louder than normal
No other fuel problems or fuel smells
Z4 ‘13 20i Mineral Grey
Z4 '07 2.5Si Montego Blue
- Marcoose
Yes, it’s kinda normal.
But very exceptional your car is so quite you hear petrol sloshing. Mine makes all sorts of sounds, noises and creaks. Good for you !
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
I don't have that sound or issue with my 2011 e89. My sons e85 did that and it was water in the sill. Had to pull the jack pads off for the water to drain.
OnlineB21
As long as it’s not sloshing around inside the cabin…
The fuel tank looks like a pair of buttocks made out of plastic…if there are no external leaks or smell of fuel you’re good…wish I could hear my fuel sloshing..must be an age thing…
A very modified Atacama Yellow 35is Previously a slightly less modified Atacama Yellow 20i MSport
Check the battery box hasn't filled up with water.
2012 Z4 2.0 M-Sport Atacama Yellow
2000 Z3 3.0
2016 Vauxhall GTC Sunny Melon Yellow
2000 Jaguar X308 Sovereign 4.0
1969 Jensen Interceptor 6.3 litre
2000 Z3 3.0
Water in the hood drains?
Likely your drain holes, had the same on mine. Surprising how much water collects when they're blocked.
- MikeyH
Had the same in my E85, drain blocked, cleared it, sound disappeared
BMWs (especially convertibles) do like to 'conserve' their water.
I had an F33 440i (not for very long obviously). That was making a sloshing noise when I got it. I drained at least 2 gallons of water out of the two rear wings. It went much better afterwards with the reduced weight!
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- Marcoose
Winner !
thanks - where are the drain holes on the E89?
I knew where they were on my E85 and kept them clear of debris
No water in the battery compartment I've checked that
I suppose it could be both sides but as theres only ever me in the car i've only noticed drivers side noise
OnlineB21
’jamesgarbett wrote: ↑Thu Sep 28, 2023 7:15 am thanks - where are the drain holes on the E89?
AFAIK there are no drain holes on E89s but didn’t want to upset the conspiracy theorists…
Ha, I missed the whole E89 board thing because I was too busy working on my flat earth diorama.
