Purchased a Z4 2.3 2011 in July.
Had a couple of issues with the roof and red light flashing.
Bought a Carly coder to check for faults.
None were stored when read with Carly.
Today had another problem.
Red light started flashing - no roof buttons pressed.
All door windows would not operate.
Plugged in Carly and it came up with 00A692, microswitch rear end module closed right.
Light went out again with windows operating once more.
Does this mean switch defective or cable break?
If so what switch should be changed.
Also is there a Carly Code Error list anywhere for all the hall sensors and microswitches.
Think I'm going to have more problems and all help will be welcome.
Cheers Jim.
Carly error code 00A692?
Seems like another faulty boot closed microswitch.
Would be nice by now if all these codes could be listed.
I'm just as guilty, i never recorded the fault codes when i had 3 various wire breaks.
I try to photograph them, then find i haven't.
- RobbiZ4
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
- RobbiZ4
Easy going by entering all possible codes into the following page:
https://bmwfault.codes/
Or via the same maintenance link on my prior post.
Not just a decode, but say a sketch pointing each code to where faults occur.
- RobbiZ4
That has been collected already as recommendation in my
E89: Retractable Hardtop (roof) Maintenance (and additional) tasks
Unfortunately, a single fault code, if present at all, cannot simply be entered 1:1 in a list of causes.
