Or in my case top nut, spring plate, spring and compressors all at once , so glad they did not hit the car.
Help me with my new suspension please....
2003 Maldives Blue 3.0i auto
- enuff_zed
If PVR is reading this he'll be glad I'm building his new front struts here and taking them down there ready assembled.
- chanlon1
You know I’ve read the above, re-read it, closed my eyes and tried to picture what you are describing and still can’tenuff_zed wrote: ↑Sat Nov 25, 2023 2:39 pm Joking aside, when you undo it obviously the springs are already compressed so you are only really holding them in that position.
Invariably the top nut will still be under a little pressure.
I use a socket and ratchet handle to undo it the last few turns, kneeling on the base of the strut and reaching forward. I do not grip the handle, just push it across with fingertips. Don't wrap your thumb around it.
You'll think it was all overkill when you do it, but why risk it.
Maybe when I attempt it, it will make sense…..
E86 Z4 Coupe 2006 Silver
- pvr
I am not insuring your teeth
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- chanlon1
My box of parts arrived in from BMW today. The Autodoc delivery is enroute and should be here this week.
Once I get al the bits, I'll look at getting some photo and lists/prices etc.
- chanlon1
Autodoc arrived early
Should be everything here I need to build all four corners
- TOMGREEN413
Looking forward to seeing your build progress, it's lucky there are so many helpful and knowledgeable chaps on this forum to help guide you through. Big Thumbsup to them
White e89 Red leather interior (But that's the wife's and don't I know it :/ )
Montego Blue Coupe manual si sport (Faster than the above....much faster
- chanlon1
A couple of months ago I signed up to a weekly night class at my local tech to do car mechanics. We have full use of a large workshop with all the tools and about 4 ramps. Makes life a bit easier
I was going to try to compress the springs at home, but we have a proper wall mounted machine, so I’ll use it instead.
- TOMGREEN413
Epic
Just in the process of doing mine, instigated by a broken front spring.
I had planned on re using my front spring plates but look at the state of them!
Good luck with it!
Good luck with it!
- chanlon1
Got the struts built up.
No humans were hurt whilst filming……
New Year project to install them.
Spring plates are pretty cheap from Cheltenham BMW, mention you are on the forum
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
Part of the appeal of my Alpina is that the previous owner had gone to town with work on it, much of which was preventative maintenance, before a continental road trip.
Full suspension refresh with the B12 kit
Gap-Tech
Brake pipes replaced
New water pump, expansion tank and all pipe work
Paint corrected and ceramic coated… I’ll redo at some point.
Some other stuff that I can’t remember, might be new front arms and some bushes… need to plow through the box of receipts at some point.
All in the last few thousand miles
A satisfying little job, will transform the way the car feels
- enuff_zed
I get to that point then think I should put them on display somewhere as they look so good
