Christmas tree lights
- MikeyH
I hope one of you knowledgeable people on here will be able to help me. Found out that the tree light transformer/controller has packed up by swapping with another one. We need to buy a new one, wife has dressed the tree, took her 3 days to do, she is not best pleased so hoping to just buy a new one and swap. The problem is that the old one is rated as sec/output 30v, 0.6A, Max:18VA and I haven't a clue what it means. On Amazon they all seem to be rated as 31V and 5 or 6 watts. Please help me save Christmas and stop my wife being really unhappy.
- pvr
Ok, the old formula of p=v*I comes in here.
So 6 watts at 31 volt means 6/31 amp is the max it can deliver.
Your old transformer delivers 30*0.6 = 18 watt. (Assuming dc output here)
Need to know if the transformer is ac or dc output though, does it say that on the output?
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Mikey;
I have several spare trannies but have looked and they are all 24 volt, so no good for you.
At 30v your 0.6 amp tranny is rated at 18 watts (that's the VA), so a 5 or 6 watt is not going to be big enough.
30 volts is unusual, even for lights; they are usually 12v or 24v.
You may need to pop to B&Q and buy some new lights!
Edit: Paul beat me to it!
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
Couldn't resist (resist; get it?)
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- pvr
Groan
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Nictrix
- davep10000
Something like this would do nicely, but you would have to adapt its output plug to your lights wire.
https://cpc.farnell.com/ideal-power/15d ... r%20supply
Otherwise, an old laptop 'brick' are often 30 volts, if you have an old one somewhere.
PS Even if your lights are AC (which I doubt it unless they are the old filament bulbs, not LED), then this will still work ok.
Just noticed one I linked to is out of stock, so this would do, and its cheaper!
2.5Si Sport
Land Rover series 1
Westfield Seiw
1938 BSA Scout under restoration
Plus some other boring vehicles.
Land Rover series 1
Westfield Seiw
- pvr
High chance they are still the old type as you know what they are like in the West Country
Wait until he tries to twist each bulb and finds the lose one
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- MikeyH
Thank you all for your advice and shedding some light on the problem, they are led bulbs, we have others that are newer and are 31V.
November is the new December!
Had the same in our house; daughter insisted on xmas trees (we have two full size and multiple little ones ) going up on Saturday. Apparently that is fine as "it's exactly a month until xmas".
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- darich
Rather ironic that PVR didn't get the formula right
Previously 2004 Sterling Grey E85 3.0SE
Currently 2007 Silver Grey E86 M Sport
Instagram - Zed4Coupe
He did! I or R can be used in Ohm's law.
PVR are his initials. His name is Paul Van Rental
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- pvr
Virtual Reality if you don't mind
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- MikeyH
It doesn't say DC but pretty sure it is as the wires are very thin coming out. We used another one from another set and it worked fine but worried it will overheat if not correct. So, to be the same as 30v, 0.6A, Max:18VA as is now what is the output I need to look for please PVR?pvr wrote: ↑Sun Nov 26, 2023 7:26 pm Ok, the old formula of p=v*I comes in here.
18 watts at 30V.
It will say if they are DC, but may be a symbol. single line with dotted line under is DC, one wavy line is AC.
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
