SOLD Z4 E85 DSC Pressure Sensors
In good working condition off a low mileage Pre Facelift car
£32 inc postage in UK
Can anyone tell me where these go and what would be the symptoms of them being faulty? Thanks
Onlinebigwinn
They bolt into the body of the dsc/abs module
You’ll be throwing codes indicating pressure switches and will have a combination of yellow warning lights
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- MikeyH
Still non the wiser
Hi...yes I have another pair for Sale ...I will Pm you.
Just done these. Will need a 27mm spanner to go with.
2003 Maldives Blue 3.0i auto
Did you have any codes?
I was literally sat in the car parked up after a drive scanning codes on ista then all of a sudden the traction control light comes on, have got code 5e21
Pressure sensor 2 fault, have had it once before but next day cleared it and it didn't come back, but this this time comes back straight away.
In ista the live data says sensor 2 is 20 bar with the car turned off, sensor 2 is nearest the bulkhead isn't it? Would a deep socket be better for removal?
04 2.2i Sapphire Black Roadster
Yes I did, I can’t remember the code but it was DSC pressure sensor 2. In live data, the two sensors were showing radically different readings (like -1 and 20), whereas on my own car the sensors were showing more or less the same reading close to zero.Joez4 wrote: ↑Thu Apr 04, 2024 11:52 pmDid you have any codes?
Swapping out both sensors with new ones solved the problem. I used one of those plumbers wrenches (mole wrench?) in the end as my adjustable spanner wasn’t quite big enough, but there’s not much room to turn it without fouling the bulkhead or one of the pipes. A deep socket may be the answer, but check for access before you buy.
You will lose some fluid. It will drip out, so have rags handy and get ready to swap in the new sensor quickly. The brakes may need a bleed afterwards.
Same issue I have, sensor 1 is -0.1 bar engine off and sensor 2 20bar ista says it shouldn't be higher than 3 bar I think.
I'm gonna flush the brake fluid soon anyway as its the only fluid in the car that hasn't been changed in my ownership.
Cheers for the help
Cheers for the help
