Fuel System Upgrade
Fuel System Upgrade
So, I am currently in the process of getting my Z ready for tuning, so far, I've purchased a PR DIY stage 2.5 (Walbro 535) kit to upgrade the stock LPFP. After the initial tune on pump gas, I will be making the car Flex Fuel capable and setting up port and Meth. injection, which leads me to the question of how to install a second pump without compromising SAFETY due to the unique configuration of the Z's fuel tank with the side mounted access lid/filter assembly. After a bit of searching, I've settled on the https://precisionraceworks.com/products ... M40i cars, I am hoping that if it doesn't fit exactly, it will lend itself to be easily modified as it is billet aluminum, what are your thoughts? anyone have an E89 filter/lid on hand to take a measurement of the flange outer diameter?
OnlineB21
Fuel System Upgrade
I think most members here haven’t wandered as far off piste as you are doing..
I took the uprated stage 1 pump in place of the OE pump.. as most folks here are running 95/98 Ron fuel..there’s no E30/40/50/60/85 here in UK..
I’ve got an upgraded EKP to match it.
In Europe there is E fuels but many countries restrict the level of modification that owners can undertake..
A friend of mine in Italy is doing a bigger upgrade but he’s not yet accessed the fuel tank..
I’ll ask him when he might..
A very modified Atacama Yellow 35is Previously a slightly less modified Atacama Yellow 20i MSport
Fuel System Upgrade
I was hoping someone has at least changed their fuel filter and still has the old one laying around , oh well.......
Fuel System Upgrade
It is 6" in diameter..
It is 6" in diameter..dumaurier7 wrote: ↑Fri Dec 29, 2023 2:45 pm I was hoping someone has at least changed their fuel filter and still has the old one laying around , oh well.......
OnlineB21
Fuel System Upgrade
I suspect on this forum it will be our little secretdumaurier7 wrote: ↑Wed Jan 10, 2024 11:50 am It is 6" in diameter..It is 6" in diameter..dumaurier7 wrote: ↑Fri Dec 29, 2023 2:45 pm I was hoping someone has at least changed their fuel filter and still has the old one laying around , oh well.......
