Roof drains .. is this a thing e89. Gallons coming in the cabin. Help!!!!
- Portisz4
https://youtu.be/i-Y_P_zvWsM?si=YkBMZPP-MSUsVqoO
Did this cause water in the 2016 e89 ?
What is this???
What is this???
Online
Nope. E89s don't have internal roof drains, as they are hardtops. All the water is (supposed) to run on the outside kept out by all the miles of rubber seals.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- Portisz4
Thank you for that. Saves me a lot of searching time tomorrow.
Let's see where this gallon of water has come from then inside tomorrow morning
Where is the water landing?
Might be an idea for someone to sit inside the car and another to use a pressure washer on the outside, you might then be able to see where the water is coming from.
- B21
Silverstar wrote: ↑Fri Jan 05, 2024 9:41 pm Might be an idea for someone to sit inside the car and another to use a pressure washer on the outside, you might then be able to see where the water is coming from.
- Portisz4
Going to do it this morning. It's in the driver seat area from front to back. I cleared it and dried it before the storms last few weeks and now yesterday is all back again. Must be 4 ltrs of water here. Pretty major fail somewhere
- IMG-20240105-WA0017.jpeg (93.85 KiB) Viewed 244 times
- Portisz4
Going to do it this morning. It's in the driver seat area from front to back. I cleared it and dried it before the storms last few weeks and now yesterday is all back again. Must be 4 ltrs of water here. Pretty major fail somewhere. Any thoughts here? The bit is so dry, I've had the door card off incase and the membrane is well secured.
Hi Portis, this doesn't seem to be that common on e89 but there is loads of the same door membrane problems showing up.
Discussed here, viewtopic.php?t=94907
Look at this at about 6.30.
https://www.youtube.com/watch?v=IVO2AFwOV2k
You say your membrane is good but are you certain it hasn't been lifted before and not sealed back properly?
I'd say on a 2016 car your seals shouldn't perish, more likely something not refitted correctly, and you are looking for a sizeable leak.
Is the boot dry, under the battery etc? Does the roof work properly? Has the windscreen been replaced? Have you checked underneath the car?
Problem with water of course is it can pool a long way from where it enters.
On your other thread on carpet removal, it might be worth the commitment to stripping it completely, at least you can do some proper tests with a hosepipe and you can dry it completely once you crack the problem.
Just seen your other update, glad you are on the right track.
I wonder if you are parking the car on a slope and this is why you have this seemingly rare problem.
I got water in the boot on my E85, when I parked it nose uphill.
Never a problem when pointing down hill or level.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Portisz4
Yes, the boot is all dry. The door membrane is definitely all well stuck down. I checked right round.Stash36 wrote: ↑Sat Jan 06, 2024 1:06 pm Hi Portis, this doesn't seem to be that common on e89 but there is loads of the same door membrane problems showing up.
I have got two threads. Apologies.
Roof works perfect. Nothing is out of place. It's most odd. Just this leak coming in now at the inside. How, we don't yet know. Winscreen doesn't appear to let anything through anywhere. Just it starts seeping water when the top screen drains start channeling it away
