The car is off in to have RTABs and LCABs swapped over to polybushes, so I thought I'd take the opportunity to refresh the cooling system (and replace what sounds like a dying pulley). I'm replacing the following parts, and I wondered if there's anything else worth doing while the garage has the front end apart?
- Nissens rad
- Genuine expansion tank
- Meyle metal water pump
- Mahle thermostat
- All three pulleys and tensioner
- Belt
It's has Vanos and DISA recently, and (surprisingly) has no oil leaks. What else is worth looking at while getting this lot done?
M54 cooling system refresh - Any other 'while you're in there' jobs?
Online
- enuff_zed
The hoses have o-rings inside that flatten over time. There is a chance that they may not reseal so consider getting new hoses as well.
That only leaves the temp sensor, which fits into the top of the lower radiator hose. If you are swapping the hose then you may find it better to fit a new sensor at the same time.
You say 'belt' in the singular. There is of course a second one that drives the AC compressor. Get that done too. Takes about 2 minutes to swap.
Onlinebigwinn
Have you replaced the oil filter housing gasket? While you have the access in the front I’d change up one of those as they invariably lose the seal and leak
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
Online
Online
The second belt was the one thing I was on the fence with. On reflection, I don't really know why. I'll get it ordered.enuff_zed wrote: ↑Wed Mar 13, 2024 11:55 am The hoses have o-rings inside that flatten over time. There is a chance that they may not reseal so consider getting new hoses as well.
RealOEM suggests 4pk863, but the Gates branded alternative is 860. Would the 3mm make a material difference?
I'll give the garage a brief on the hoses, but the only OEM options I could find seemed ruinously expensive! Are any of the OE options worth buying (Gates is the only brand I recognise)?
- enuff_zed
I use mostly Gates for belts and hoses tbh. I think the hoses are around the £30 mark from what I recall (each).DaveP wrote: ↑Wed Mar 13, 2024 12:58 pmThe second belt was the one thing I was on the fence with. On reflection, I don't really know why. I'll get it ordered.enuff_zed wrote: ↑Wed Mar 13, 2024 11:55 am The hoses have o-rings inside that flatten over time. There is a chance that they may not reseal so consider getting new hoses as well.
Failing that Febi Bilstein are ok as well.
3mm on the belt length will easily be taken up by the tensioner. Tbh, it'll probably stretch that much in the first couple of months.
Online
Roger that. Car goes in on Monday, so I'll see if I can get them ordered in time.enuff_zed wrote: ↑Wed Mar 13, 2024 1:29 pmI use mostly Gates for belts and hoses tbh. I think the hoses are around the £30 mark from what I recall (each).DaveP wrote: ↑Wed Mar 13, 2024 12:58 pmThe second belt was the one thing I was on the fence with. On reflection, I don't really know why. I'll get it ordered.enuff_zed wrote: ↑Wed Mar 13, 2024 11:55 am The hoses have o-rings inside that flatten over time. There is a chance that they may not reseal so consider getting new hoses as well.
- BumpyZ4
I've had "Rein" upper and lower radiator hoses on mine for the last few years with no issues.
2003 E85 3.0i Sterling Gray
KLR 650
Diva Roadster (Kit Car)
KLR 650
Online
Struggling to find the longer hose in stock in time, annoyingly. This one might have to wait.enuff_zed wrote: ↑Wed Mar 13, 2024 1:29 pmI use mostly Gates for belts and hoses tbh. I think the hoses are around the £30 mark from what I recall (each).DaveP wrote: ↑Wed Mar 13, 2024 12:58 pmThe second belt was the one thing I was on the fence with. On reflection, I don't really know why. I'll get it ordered.enuff_zed wrote: ↑Wed Mar 13, 2024 11:55 am The hoses have o-rings inside that flatten over time. There is a chance that they may not reseal so consider getting new hoses as well.
