Closing the roof from the key ?
Hello ,
On my car I can open the roof from the key but not shut it . Is this something that can be coded in via Carly / bimmercode ? Or something actually physical that’s needed ?
Thank you
Thank you
- markplant
Do you mean you can openit if you press and hold unlock
- markplant
If yes it can be coded, just worth checking, put key in drivers door turn and hold in the lock position, hold till it completes the cycle
Yes , so at the moment I can hold the unlock button down on the fob and the roof will come down … but when I hold the lock button on the fob … the roof doesn’t shut .
- markplant
Needs to be codedBodyboarder wrote: ↑Thu Mar 21, 2024 7:09 pm Yes , so at the moment I can hold the unlock button down on the fob and the roof will come down … but when I hold the lock button on the fob … the roof doesn’t shut .
Just to mention when it's done
You'll press and hold and the roof will close but it'll time out before windows go up , so you'll just need to press and hold lock again for the windows to close
Or buy a gaptech
Ok thanks for the info ……
Sorry another question then …with the roof in its closed position but the windows down , when i press and hold the lock fob button , the windows don’t go up . Another coding thing ?
- markplant
Yes probably, all part of the same anti trap I guess, BMW don't want you to be able to cause a accident by closing roof/windows while been away from the car
Thanks mark appreciate the info
- markplant
Not a problem, hopefully someone on here will be able to help get it coded for you
- enuff_zed
I can. In Norfolk
Bit of a trek from Southampton for that , but appreciate the offer . Think I know of a few my way who have bimmercode
My car has been 'carlyed' at some point in prior ownership and does the same, wont wind the windows fully up. Kind of defeats the point really that you have to go back to the car to close the windows
Currently BMW Z4 E85 3.0si
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 Turbo
Toyota Celica ST205 GT4
Nissan R33 Skyline GTST
Vauxhall VX220 NA
Nissan 350z
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
- enuff_zed
Yup, scanner 1.4 does it easilyBodyboarder wrote: ↑Fri Mar 22, 2024 1:23 pmBit of a trek from Southampton for that , but appreciate the offer . Think I know of a few my way who have bimmercode
coldel wrote: ↑Fri Mar 22, 2024 1:56 pm My car has been 'carlyed' at some point in prior ownership and does the same, wont wind the windows fully up. Kind of defeats the point really that you have to go back to the car to close the windows
Can you not just hold the key down a 2nd time then to close the windows ?
- enuff_zed
Sometimes mine go fully up, other times they don’t. I know it is self defeating but if I stand closer to the car it usually works.
Only time I’ve actually found it of any use was a few weeks back. Four on the drive with roofs open to air when the rain started. Me stood like some kind of demented scarecrow trying to press four fobs at once.
