As above really, what's everybody using to clean the inside of the rocker cover of oil/gunk? I have some engine degreaser but I didn't want to compromise the plastic cover.
Thanks,
Andrew
Inside Rocker Cover Cleaner
Z4 E89 28i Sapphire Black - gone
Z4 E85 3.0i Sapphire Black
- 1536Z4
I used kitchen towel to get most of it out and then some bike chain degreaser but I don`t think the engine degreaser will harm the plastic . Probably worth a google search
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
I tried the search function and Google but saw mixed responses on Google. Some people warned about thr plastic potentially turning brittle and cracking.
- 1536Z4
Ok I suppose it depends on the formulation . I used muck off degreaser with no problems . https://www.amazon.co.uk/Nano-Tech-Litr ... NQHYC&th=1
- enuff_zed
I used Surfex HD, mixed about 1:5 in water. Sprayed on and agitated with a stiff brush then hosed it off.
Some bits needed a second go
- 1536Z4
Good stuff that , I use it on the car but I didn`t even think about using it for the rocker cover
- BumpyZ4
Pressure washer works wonders!
2003 E85 3.0i Sterling Gray
KLR 650
Diva Roadster (Kit Car)
KLR 650
The adult super soaker did spring to mind but I've got no way of capturing the oily water spray without it making a big mess of something else.
Had a go with some engine degreaser last night and it work reasonably well. Still some gunk in there but relatively lean now. Thanks for the ideas folks
