Bored today and tried an experiment
- chanlon1
Replaced my rocker cover recently and had all the old head bolts left over as they are deemed single use.
Decided to see how much you could torque them before they snapped.
When installing new ones on the engine, they say to torque to 7nm, leave 30 minutes and then turn further 90 degrees.
Assuming my old ones were slightly stretched already, I know they weren’t as strong as new ones, however on more than enough of them, as soon as I got to 13nm, they snapped.
12nm and they were fine, 13nm they snapped.
Not highly exciting but killed the time in between rain showers…..
E86 Z4 Coupe 2006 Silver
- 1536Z4
I think that was a great experiment and good to know
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
All good, presuming your torque wrench has been calibrated recently.
7-13nm is not a lot, just over 'fully seated' so there is a huge margin for error on a less than high precision spanner.
Passes the time, though, I suppose.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- chanlon1
True - tightening to 7nm isn't much, but when you are doing this for your very first time and they say to go a further 90 degrees....paranoia kicks in very quickly that they'll snap
- N4LLY
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- DMike
- enuff_zed
Were these bolts magnetic?
- chanlon1
Nope.
Not sure what type they were, but they were very light.
- enuff_zed
So they would have been the alloy ones. Bears out my theory that I was ok to reuse the steel ones I had on mine
- pvr
And now getting the snapped ones out of the block
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- chanlon1
since they had been already used, I suspect they had been stretched to some extent, so its possible brand new ones last a bit longer than 13Nm.
