Error Codes 985D & 985F airbag light on dash
Silverback355
Post by Silverback355 » Tue Apr 09, 2024 1:48 pm
Hi guys,
So the airbag light came on the other day and after I plugged my Ancel bm700 reader in it came up with 985D & 985F. So I understand it's the pre-tensioner for the passenger seatbelt. Would the remedy be to just change the pre-tensioner ?? My car is a 2.0l 2005. It's done 102k. Thanks guys if you can help.
enuff_zed
Post by enuff_zed » Tue Apr 09, 2024 2:18 pm
Silverback355 wrote: ↑Tue Apr 09, 2024 1:48 pm Hi guys,
Just to confuse you further, it may actually be the SBSL (left satellite module). Get the carpet up and see if it's wet. Then check the plug for any signs of corrosion. Also worth a bit of contact cleaner just in case.
It sits right at the bottom rear corner of the inner sill where it meets the B-pillar.
As per this person's problem:
https://www.bimmerforums.co.uk/threads/ ... ft.390666/
While you're in there, get a photo of the label with the part number on. I may be able to help you. :thumbsup:
HQ of 'Norfolk Zed Rescue'.
Silverback355
Post by Silverback355 » Wed Apr 10, 2024 6:31 am
Hi, thanks for your reply. So the SBSL can throw up an airbag light ? I would never have thought there was anything like that under the carpet. I'll have a look this afternoon and take a photo for you. Thanks mate. Appreciate your help πŸ˜‰πŸ‘
enuff_zed
Post by enuff_zed » Wed Apr 10, 2024 7:16 am
Silverback355 wrote: ↑Wed Apr 10, 2024 6:31 am Hi, thanks for your reply. So the SBSL can throw up an airbag light ? I would never have thought there was anything like that under the carpet. I'll have a look this afternoon and take a photo for you. Thanks mate. Appreciate your help πŸ˜‰πŸ‘
To clarify, this applies to prefacelift only. Facelift used a slightly different system.
Silverback355
Post by Silverback355 » Wed Apr 10, 2024 10:35 am
Thanks,
Doe's a new module need to be programmed into the ECU ? Do I need to remove the passenger seat to get to the SBSL ? πŸ˜‰πŸ‘
enuff_zed
Post by enuff_zed » Wed Apr 10, 2024 12:37 pm
Silverback355 wrote: ↑Wed Apr 10, 2024 10:35 am Thanks,
I assume pre-facelift then?
Seat forward, remove the inner door sill trim and the curved piece behind it, pull the carpet up a bit and you'll see the module bolted to the rear of the inner sill.
You will need either the same part number, or any that Realoem shows as exchangeable.
Once connected up there is a bit of a software dance between INPA, NCS Expert, Winkfp and Toolset32 in order to input your car's VIN and system time. Plus a little bit extra if it is not the exact same part number.
I have a few left satellite modules here and the ability to code them in.
Silverback355
Post by Silverback355 » Wed Apr 10, 2024 3:30 pm
Hi, thanks for the heads up on location and how to do. Sorry to mention that it's Pre facelift. So you would be able to help me out with a unit and I would have to send you the VIN number. ? That would be great. Thanks. πŸ˜‰πŸ‘
enuff_zed
Post by enuff_zed » Wed Apr 10, 2024 4:08 pm
Silverback355 wrote: ↑Wed Apr 10, 2024 3:30 pm Hi, thanks for the heads up on location and how to do. Sorry to mention that it's Pre facelift. So you would be able to help me out with a unit and I would have to send you the VIN number. ? That would be great. Thanks. πŸ˜‰πŸ‘
Not the VIN, I need to know the part number.
Just post up a photo of the whole label.
A replacement module needs to be physically plugged in to your car and coded through your OBD port. This cannot be done remotely then posted to you.
There are companies offering a cloning service but I believe this only applies to the centre (SIM85) module.
So then it just boils down to your location. There are others dotted about who could help and may be much closer to you.
Silverback355
Post by Silverback355 » Thu Apr 11, 2024 6:13 am
Thanks, I'll strip the sill out this afternoon, we've got a dry day up north today. πŸ€¦πŸ˜‚ I'll take a photo. Thanks enuff_zed. πŸ˜‰πŸ‘
enuff_zed
Post by enuff_zed » Thu Apr 11, 2024 7:31 am
Silverback355 wrote: ↑Thu Apr 11, 2024 6:13 am Thanks, I'll strip the sill out this afternoon, we've got a dry day up north today. πŸ€¦πŸ˜‚ I'll take a photo. Thanks enuff_zed. πŸ˜‰πŸ‘
I’m a long way from you then.
Bigwinn is in Lincoln and Street in Newcastle.
