WANTED Airbag Sensor Module
Hi,
I’m after an airbag sensor module part number 6776928571, it is for the passenger side, after mine gave up the fight after possible water damage. Also if anyone can tell me where to get it coded to my VIN number, I would be most grateful!
Regards
Garry Clark
Regards
Garry Clark
OnlineUsel
Where in the UK are you? I am sure someone on the forums can help you code it
I have one left a passenger side
6776945158
I will check Real OEM compatibility
6776945158
I am in South Somerset, but I’m willing to travel to get it sorted. I do have a replacement, but it is an exchangeable superseded number.
My original number is 65776928571, according to Realoem, the other sensor I have is 65776948087 which is exchangeable retrospectively, so I take it if I can get it coded, I can use it?
OnlineUsel
Umfaan above is in Cardiff so should hopefully be able to help you
Usel , you are a gentleman amongst men! Thank you!
Umfaan, is there a chance I can code this to my car, and if so, can you help me?
Thanks in advance
Garry
Thanks in advance
Garry
- enuff_zed
Bit late to the party but yes that can be coded. I’ve done several lately but I’m in Norfolk
Hi enuff zed, I did send you a message by other means earlier!
Col is the expert in Newport……he should be along soon.But I will let you have his number in PM
- enuff_zed
What other means?
I haven't seen anything? Just double checked my PMs as well.
enuff zed, I sent you a message on Messenger, have you not received it?
Thanks Umfaan, much appreciated!
Thanks Umfaan, got your message, you Sir are a diamond!
- enuff_zed
Caught up now.
