Just got back from a visit to NAD UK, in Littlehampton near Brighton. (https://naduk.co.uk/
After having a decent setup from Center Gravity a few years ago now, I took it to a local-ish tyre place (not Kwik Fit!) to put it back to the settings I had from CG. They had a Hunter machine, and I provided the print out of the settings, sounded like it wouldn't be a problem. As it turns out, it was a problem, they made a pigs ear of it to be honest and didn't manage to do much let alone get it back to the settings I wanted. Don't really know why as nothing was seized, far from it. Either way, bit of a waste of time and money.
I'd heard good things about NAD so decided to take a trip down there to try and get it sorted again for this year. He checked over the car on the ramps making sure it was all in good order, even picked up a few unrelated minor things which was good to know and can add to my list.
Talked me through what he was doing and set the car up exactly how I wanted, spot on to the previous setup, with some added camber. No issues at all and no problems adjusting anything. Basically he knows what he's doing and is clearly an enthusiast, unlike a lot of places with Hunter machines but that's no real surprise, should have known better the first time! Only as good as the person using it even when you provide the settings.....
Checked the corner weights again which were still good from last time so no adjustment needed there.
Was happy talking cars the whole time I was there as well which was an added bonus, don't usually like getting in the way of someone working but he was more than happy to oblige and had an enjoyable chat. A couple of hours very well spent! Has a cracking M3 there that's well worth a look.
Will be my go to alignment shop in the future and highly recommended
NAD UK - 4 Wheel Alignment
- AndyBeech
Z4MR - Gruppe M / Bilstein PSS10 / CSL's + 18" CSL reps with semi's / RTAB Limiters / Powerflex’d / PF Camber Arms / K-Sport BBK / RSL-29 / GC Camber Plates / Strut Brace / Exhaust valves / custom brake cooling / 4.1 FD / underside refresh!
Excellent nugget - this is not too far from London for travelling so will definitely take mine to this fella once tyres are swapped and steering problem bollox is sorted.
2010 E89 35i — turbo boat hooligan - viewtopic.php?t=131886
2008 Ducati 1098S — two wheeled nightmare
- AndyBeech
It's a nice drive through the South Downs past a Caffeine and Machine as well depending which way you go. Good roads to test the setup afterwards
3 degrees front camber . You must like corners.
- AndyBeech
Haha, yup! Gotta preserve those outside edges on trackdays Wasted too many tyres now ruining the outsides, though that's probably the drivers fault as much as the setup
