Sound Generator Modification
- The Moo
Re: Sound Generator Modification
Since moving up from my old 2.8 Z3 to Z4 the only aural pleasure I have had has been provided by my wife (in the form of her Mondeo V6, which sounds georgeous under acceleration)
Just read this how to and have removed just the sponge from the bulkhead end which is literally a 2 min job no tools required. and have been for a blast up the bypass and wow Car now sounds superb under brisk acceleration and remains quiet cruising at a constant speed. Sponge is safely inside glove box but I don't think I will rush to put it back on!!
As mentioned by others I think there might be an increase in fuel consumption and I seem to have relearned how to double declutch as taught by my old man just to remind me how good it sounds!!!
One happy teddy. Excellent How too SK93
2004 3.0 SE Manual Now gone but never forgotten!
Now running 2007 Audi TT Roadster 3.2 V6 S Tronic in Metallic grey with grey leather. OEM Sat Nav etc.
- Rudd
hey guys, just a quick one that has probably been answered before.
does the sound generator come as standard on an 03/53 3.0litre? there is one in the scrappy just down the road from me and il go along and get it.
how much would you expect to pay for a second hand one of a car from a scrappy?
- sk93
yeah.. it comes in the 03 3.0 litre, cos that's what I've got
they're £60 from the dealer brand spanking new, so I'd go and offer £15.. maybe £20.. and at a push, £30...
gl.
gl.
- Rudd
i take it they are easy to locate/recognise in the engine bay, i just dont want to look a fool when i go down
and do you know if it will fit straight to a 53 2.5i?
great writeup btw
great writeup btw
- sk93
afaik, they'll fit straight in.
and you can't miss it
if you look on the right-side of the engine, you'll find this big lump of plastic attached to the back right side.
if you look at my pictures earlier in the howto, you should be able to work out what you're looking for.
EDIT: Here's a guide for what you want
- Rudd
ok cheers, so its just the pipe, generator box jobby thingy and nothing else. or do i need to take something from the firewall i.e number 7 or 8 in your diagram?
- sk93
I'd grab no7 as well if it's there.
you'd also need the modified air intake pipe that this all connects to.
I cant find it on realOEM at the moment to give you a picture, but you'll know what I'm on about if you have a look see.
i can give you my mobile number if you like, so if you get there and aren't sure, you can give me a bell?
- sk93
ok.. found it
it's part number 5. the left end of part 1 in the original document, will be plugged into this part, at the point where it says "6" on this diagram
in all, you should end up with this lot:
- Rudd
Cheers for all of the help, thats geat!
i think i would be able to handle it from all of the info you have given, ill basically take everything from the intake pipe back. and ill print off some of the bits and bobs on here.
i just need to decide how much foam i want in or out now
ill stick an update up on how i get on
thanks again!!!!
thanks again!!!!
- sk93
pleasure.
good luck
good luck
- Rudd
Ok so sound generator fitted today! grabbed it for a tenner, bargain.
i tested the different bits of foam and opted for the small peice still in, i tried without any and OMFG i felt like part of the asda carpark crew!
one question, probably for SK93 the fixing clip on the bottom doesnt seem to have anything to get hold of on the 2.5i engine or have i just missed a bit theat i should have taken off?
- Kaide
I removed both pieces... WOW very loud! Put the small piece back in and away we go... I'm gonna keep this for a bit.
03 Z4 3.0i / 6 Speed / Dinan CAI / Dinan Ram Air / Dinan Stage 2 Software / Dinan Strut Bar / My car
98 Honda Superhawk / 101whp
"Life is a game of relationships"
- Rudd
it sounds minging with both removed. i started by taking the little bit out and there wasnt much difference, then when i took all of it out i nearly shat myself. it sounded like something was wrong with the car!
so i stuffed the little bit back in and that sounds fine
I've been running it with both removed since November!
- nav, prof. sound, PDC, individual estoril/anthracite interior
- folding mirrors, heated seats, intravee II, stubby!
- Rudd
someone doesnt fancy taking a pic of the bit that the clip on the bottom connects to on the engine block next time they remove it do they?
just so i can check if i have missed a bit when i took it off the other car. thanks in advance
