yesambok wrote:is this easy ti install. . ???
Build and install your own AUX Cable!
- gannet
Re: Build and install your own AUX Cable!
-- Gannet.
Current: MINI JCW... - Modification: Driver Upgraded
Previous: DS3 DSport, Z4 3.0SE, 206 GTi & XS, Alfa 147 Lusso
thanks for the guide! so easy and works perfect much better than paying the prices BMW wanted!
Hi Everybody. i dont know if this forum is still looked at but was just wondering if anybody could help a little.
I have made the aux cable and tried fitting it into my z4 but i just cant seem to get it to work.
The problem is I have a 2003 z4 with widescreen business navigation, sat nav system with CD changer and amp in the boot.
I know the cable is working because i plugged it into the same pins that the sat nav voice comes through and could here the music i was playing when changing the sat nav voice volume.
When i tried plugging it into the proper pins, there was no aux option. i tried cutting the power to the radio head unit but still nothing.
Any help anybody could give me would be greatly appreciated.
- avolkov
Just made mine. Have navi and bluetooth. Works just fine, 2 hours of time (including installation) and 1,5 Eur of parts.
Did not remove the vents, reached throught the lover panel. It easy to reach the connector, you just have to know what to look for and where is the retaining clamp.
- avolkov
Try to make the connectors tighter, had simmilar problem at start, but then squised the connectors a bit.nick2310 wrote:Hi Everybody. i dont know if this forum is still looked at but was just wondering if anybody could help a little.
Looks like the wrong value Caps being used, according to BMW, they sould be 0.22 F. Please follow link, http://www.m3resource.com/downloads/AUX ... trofit.pdf, and see circuit diagrams on last page. The value of the Caps will alter the frequency response of the circuit and therefore may be the cause of the poor bass response.
What is the GOOD value of the Caps that don't will alter the frequency ?DELBOY691 wrote:Looks like the wrong value Caps being used, according to BMW, they sould be 0.22 F. Please follow link, http://www.m3resource.com/downloads/AUX ... trofit.pdf, and see circuit diagrams on last page. The value of the Caps will alter the frequency response of the circuit and therefore may be the cause of the poor bass response.
Hi there,
I decided that I would try and have a go at this aux cable for my bmw, and im pretty sure I got it all right, however, I am not getting an aux option on my radio I have attached a few pictures to display my efforts at creating the circuit, any and all help with it is greatly appreciated.
http://dl.dropbox.com/u/24435962/IMAG0019.jpg
http://dl.dropbox.com/u/24435962/IMAG0020.jpg
http://dl.dropbox.com/u/24435962/IMAG0021.jpg
I suppose there is a chance that I burnt out one or both of the capacitors, I know that it is easily done but im not convinced.
Hello,
Can anyone confirm what colors the cables are that go in the 6 and 12 pin locations?
Thank You!
Thank You!
Fitted mine yesterday and on mine the White cable went into pin slot 3, Red cable went into pin slot 4 and the Green cable into pin slot 10.RyanTheFizz wrote:Hello,
Thank You!
Mark
Thank you for the response, however I was referencing the two cables for the phone/sat nav that share the connector with the aux wires.
I will be working on this tomorrow and try and grab some pictures.
~Fizz~
~Fizz~
- LeeME3
First post! Thanks for the guide - built my own last night and it works superbly. Bass is fine, very slight background hiss at volume but barely noticeable and may be able to eliminate that with better screening and connections.
Just becuase my soldering is, basically, abysmal, I built it using terminal blocks initially - also has the advantage of keeping the parts apart so reducing shorting risk (although you should still insulate everything). Will probably leave it like that as it makes component replacement a doddle if ever it fails - will mount it in a mini 'project box' though to further insulate and protect it. Like most folk...2 hours to get those blasted vents out, 10 mins to build the cable and 5 mins to install! Less than £7 in total using Maplin parts.
Next on the list...stubby aerial, retrofit steering wheel audio controls, gaptech dual module - yep, had the car a week and can't resist modding it already! Already done the foam pull from the sound generator.
- Hosse
Question. I cant decide if i want the contact in the front under the dash or in the compartment between the seats. Is it possible to connect 2 contacts in paralell? Could this work if I only use one at the time?
Best regards
Hosse
"Norway - Z4 2.5IA E89 - 320D F31"
Hosse
- LeeME3
Should do, just bear in mind every 'contact' you add has the potential to add more noise to the circuit (especially if your soldering is as lousy as mine.)Hosse wrote:Question. I cant decide if i want the contact in the front under the dash or in the compartment between the seats. Is it possible to connect 2 contacts in paralell? Could this work if I only use one at the time?
2003 Z4 3.0i
Done: DIY Aux cable, stubby, sound generator foam delete, gaptech, brodit pro, M wheels, ditched RFTs
To do: Steering wheel audio.
- Hosse
Notify
Best regards
Hosse
Hosse
