kangaroo hop
- scottie1979
kangaroo hop
I have been experiencing this problem since i got the car a few days ago.
It usually happens when going into 2nd gear from either 1st or 3rd. I select 2nd then come off the clutch and the car starts to kangeroo hop or judder under acceleration. Usually i just give it more gas and it pulls out of it.
Just wondered if anyone else has this happen to them?
I know it is probably my crap driving. Im used to coming of the clutch at a steady rate while applying the gas. But reading about the CDV perhaps i should just come straight off and let it do the work? New car requires new techniques....
Not after any driving tips just wondered if anyone else has had this? I would hate to do this with a mate in the car. Have my image to uphold !
Re: kangaroo hop
Is the engine cold and the kangaroo'ing stops when it warms up? Apparently the engine runs lean when cold to heat the catalyst up quicker and this causes a little hesitation and normal unleaded makes this a little worse.scottie1979 wrote:I have been experiencing this problem since i got the car a few days ago.
I'm on my second Zed, a cosseted 2007 Interlagos Blue Z4M Roadster owned since new - 343 horses controlled by a donkey...
Daily driver is a 2012 X3 3.0d M Sport (fantastic) Wife has a 2015 325d Luxury
IAM Observer
IAM Observer
- Shunt
Re: kangaroo hop
I have this as well, more obvious when cold but can easily drive around that. It happens to me when pulling out of a junction in 1st, i think the traction is cutting in and out and amplifies the problem. I must be getting used to it now though as it doesn't happen as often. Replacing the CDV helps lots.
Aston V8V
- Veruca
Re: kangaroo hop
Okay, I didn't have the opportunity to experience the car before the cdv was removed but I still get the 'kangaroo hop.' Not the humiliating bucking - I learned that lesson after the first time it happened, but a little jerking no matter what. It definitely improves as the car warms up. Also, my down shifts are really abrupt - mostly from 3rd to 2nd. I'm trying to learn the heel/toe to remedy this but I still have a long way to go.
Re: kangaroo hop
Keep your RPM up. It's a very touchy clutch, and the car's gear are spaced in a way that if your up-shift point is above 4,000 RPM your shifts smooths out.
On down-shifts make sure you blip the throttle accordingly. If your engine's RPM matches wheel speed you will feel no jerkiness.
- inTgr8r
Re: kangaroo hop
^+1 4K is magic
- scottie1979
Re: kangaroo hop
Good to know it isnt just me.
It can happen when the engine is hot or cold. I haven’t noticed any difference. Nothing to do with the traction control the light never flashes during.
Obviously the warranty is voided if i get the CDV replaced? Have many of you done this? Aint the best under the bonnet so perhaps i will just try and keep the revs higher.
Thanks for all your help.
- Top pup
Re: kangaroo hop
You haven't got the sport mode on have you? Sport mode makes the car very prone to kangarooing around town.
Removing the CDV helps greatly too, you don't realise how wrong the clutch feels as standard untill you drive the car without a CDV.
- Color
Re: kangaroo hop
Don't worry - it's a matter of practice . . or should I say getting used to the clutch/throttle settings. I drive with sports on most of the time and manage to drive quite smoothly - The first times were a kangaroo nightmare though.
- All Pina
Re: kangaroo hop
Removing the CDV does help, but is not the total solution. I am now more concious that I need to lift clutch to full travel on the 1-2up shift, and as said keep the right foot "in" on revs. Rightly I suppose, the setup seems to favour an agressive approach. And yes, dont even think about Sport mode around town. I am still smarting from the humiliation of kangarooing off a roundabout, closley followed by four hysterical lads in a small Pug
The 3rd chapter in my Z4 odyssey - 35is Melbourne Red, Black Kansas, DCT, 326M 19"s.
Now the 4th chapter - SDrive20i M Sport Manual, Sapphire Black, Beige Kansas, 326Ms
- PaulN
Re: kangaroo hop
The only solution once your hooping is to power out of it, but its not a great look!
I guess its a bit like a Tank wobble when on a bike, power out or hope for the best.
PaulN
PaulN
Everything Happens for a Reason!
14 TT Black Edition
07 Z4 2.0 SE Jet Black
06 Freelander Sport Java Black
14 TT Black Edition
- Gauss
Re: kangaroo hop
It's possible to compensate for CDV once you learn how to drive it more. After a year I don't even notice the issues.
Re: kangaroo hop
I'll second that. You don't need the CDV removed to ensure smooth shifting, you just need to "get into the groove" and learn the feel of the transmission to get the best out of it.Gauss wrote:It's possible to compensate for CDV once you learn how to drive it more. After a year I don't even notice the issues.
Whilst i respect the decision of those that have, I personally wouldn't remove the CDV. Its there to reduce shock on the drivetrain and i'd rather trust this risk reducing design of the extremely capable BMW engineers.
///Merefield
- MyMRoadster
Re: kangaroo hop
It only happens to me when there is a good looking gal checkin' out my car. I'm sure it looks like a bucking bronco (or a kangaroo) as I make my way through the intersection.
I blip on all downshifts, even in my pickup truck ... so I rarely see it then. But from 1st to 2nd it is an issue, especially in sport mode.
