Compressor for zed
- sp3ctre
- Site Admin
Compressor for zed
Having binned the run flat tyres I have a can of tyre weld in the back.. I would like to purchase a small compressor to keep in there... any particularly good ones? (UK)
- Wondermike
- Moderator
- sp3ctre
- Site Admin
- cj10jeeper
The cheapest tiniest pump from Halfords will do just fine as you don't want the weight. If you can't get the tyre to seat on the rim and seal then run a ratchet strap around the circumference. Tighten it and it will squash the tread causing the beads to seat.
I have a fair amount of experience in this area. The eagle eyed will spot I run some Jeeps all with on board air system. The largest runs a 13cu ft belt driven compressor with 250psi 10l reservoir airtank . I can easily run airtools off road, but probably overkill for a Z4....lol
- sp3ctre
- Site Admin
Thanks mate!...cj10jeeper wrote:The cheapest tiniest pump from Halfords will do just fine as you don't want the weight. If you can't get the tyre to seat on the rim and seal then run a ratchet strap around the circumference. Tighten it and it will squash the tread causing the beads to seat.
<off to Google to see what the hell a "ratchet strap" is!>
- cj10jeeper
Sorry - used to fasten things down. You see big one's on trucks, but you can get little ones from anywhere like Machine Mart
http://www.machinemart.co.uk/shop/produ ... et-lashing
- sp3ctre
- Site Admin
