BMW Strut Tower Brace
Re: BMW Strut Tower Brace
FWIW the instructions that come with the DINAN brace instruct you to fit the brace with the car on flat, level ground and to tighten the supplied nuts to 18 ft-lbs
2005 Z4 3.0 Supercharged
1988 325iX
2003 R1150R Rockster
1988 325iX
- Smokin
Finally got my OEM brace fitted-glorious afternoon and I had time to finish... I'm hoping it doesn't rub on the air intake as it sits *right* on it. It's going to be a bit of a PITA, though, as I'll have to remove the cross piece before I get my oil changed. Good thing it's only once a year!
Before:
another angle:
possible rub point:
right bracket on:
left bracket on:
cross piece on:
cross piece tight against the air intake:
I'm hoping that doesn't rub. Shouldn't if it doesn't move, right? Sorry for the dust, but we're steady into pollen season, .
Before:
another angle:
possible rub point:
right bracket on:
left bracket on:
cross piece on:
2007 3.0si coupe, sapphire black, saddle brown extended leather, heated M seats, premium package, sport package, Carver, light poplar wood trim, xenon, headlight washers, 6 spd. Member BMWCCA, ZSCCA, Homecoming 08 Pirate.
- Caddyshk
Funny - It's a better application on the M? Looks good - hope you don't need oil BTW - Put the black nut caps on...
2006 Z4MC IB - LL93158
SS Race M, RE X Pipe, FS Headers/DFK Sec 1, OE STB, DZ CDV, AS SS, GC CoilOvers, SP FCAB, RE RTAB, VT Engine Mts, Stoptech lines, Hawk DTC, RE Clutch Stop, RE Tran Mounts, LeatherZ MSB, Tekarbon Spoiler, CF Grills, Advan RS
- Smokin
I have them. This was a used brace so should they still fit tightly enough? Don't want anything flying around in there...Caddyshk wrote:Funny - It's a better application on the M? Looks good - hope you don't need oil BTW - Put the black nut caps on...
- Rick Hunter
Might want to put a bit of glue to keep them in place. Otherwise they WILL fly off eventually.
'07 Imola Red Coupé
- Smokin
suggestions on type of glue? Just a dab of Elmer's? Remember, I have to take off the cross brace to change oil.Rick Hunter wrote:Might want to put a bit of glue to keep them in place. Otherwise they WILL fly off eventually.
First impressions are positive. Maybe I'm searching for effect, but the car seems more "up on her toes" and not quite a flat footed-might also have to do with tightening the factory firewall-to-tower brace (was tight by firewall, but at the towers, one needed a good quarter turn to hit 25 ft.lbs). Also seems that I get better feedback through the steering wheel. Bumps seem to hit more mid-car than all up front. We'll see tonight when I drive a road that has *always* tramlined (even in my 325).
- Rick Hunter
To be honest, I never put mine on (I spoke with other owners who also said they had lost a few of the rubber pieces while driving). I like the look of all silver vs. silver with lil' black caps. Sorry... I don't have any suggestions.
'07 Imola Red Coupé
Bling factor got me tooRick Hunter wrote:Not yet. But here it is: NO SIGNIFICANT DIFFERENCE noted on a Coupé for day to day driving. The bling factor got the best of me this time. ---
Jim Millet
2007 E86 Z4 M Coupe', Imola Red, Black Leather with Carbon Leather Trim, Premium Package, Nav, Heated Seats, HD Radio, Strong-Strut, RPi Intake Scoop, CDV Delete, Cupholder Delete, TC Kline DA Coil Over Suspension.
- Breaker
Just put a dab of clear silicon on top of the nuts before fitting the caps.Smokin wrote:suggestions on type of glue? Just a dab of Elmer's? Remember, I have to take off the cross brace to change oil.Rick Hunter wrote:Might want to put a bit of glue to keep them in place. Otherwise they WILL fly off eventually.
3.0si Z4 Coupe then an sDrive 35i Z4. Great cars, now gone. Range Rover Evoque owner now!
- Smokin
Duh, why didn't I think of that. Good old rubber cement had passed my mind, but not the modern equivalent...Breaker wrote:Just put a dab of clear silicon on top of the nuts before fitting the caps.Smokin wrote:suggestions on type of glue? Just a dab of Elmer's? Remember, I have to take off the cross brace to change oil.Rick Hunter wrote:Might want to put a bit of glue to keep them in place. Otherwise they WILL fly off eventually.
- Breaker
Actually, I think it looks better without the black caps on.
How much was it? Been thinking of buying one for mine.
