M Sport Button
- khooni
Re: M Sport Button
agreed .. completely useless on the z4m
The standard mode is already too aggressive in my opinion.
Re: M Sport Button
It's snake oil as others said, the map is identical, it doesn't even make it more drivable. It just adjusts input sensitivity, it can make heal and toe easier though. But I've learnt to be a bit more direct on the standard position, which required a bit more focus initially
Imola Red Z4MC Currently up for sale: CLICKY
- ChawenHalo
Re: M Sport Button
I wish we had an M engineer on this forum.
Re: M Sport Button
Why? To ask why the button doesn't do more? It changes the input required on the throttle for the throttle position at the engine end.ChawenHalo wrote:I wish we had an M engineer on this forum.
In normal mode you press the peddle down 20% you get 20% throttle, all the way up to 100% pressed gives you 100%.
With Sport button on you press the peddle 20% you get 30% throttle, 40% gives you 70%, 50% gives you 100%. - all numbers are for illustration etc, this isn't actual figures etc.
It does not change steering (we don't have elec steering on M), it doesn't change dampers (we have normal simple oil filled dampers), it doesn't change ESP (you can always get some slip with TC on), it doesn't change gear change speed (we have a stick) - it's only there because the marketing boys asked for it!
I have never seen anything (from an official source) that says otherwise.
- Andy
Re: M Sport Button
Turn key, start engine, roof down, dsc off, sport on.
clutch in, first gear, drive.
Imola Z4MR #0026 6 yrs, & 66k so far..
- mcbeee
Re: M Sport Button
On my M3 all it did is change the throttle response to a linear response from a learned curve response, ( The car jumps if you are on the gas when you press the button) and it increases the fun factor by 2x.
Sold the Z4 M Roadster and a 911 Carrera S now I have a 2021 Z4 3.0i
- BMWZ4MC
Re: M Sport Button
Absolutely! Out of sport mode, the throttle does almost nothing for the initial part of its travel.Aliv6 wrote:I use it everyday! BMW's throttle response is horrific!!!!!
Really??khooni wrote:agreed .. completely useless on the z4m
Turn key, sport on, start engine, DSC off,Andy wrote:Turn key, start engine, roof down, dsc off, sport on.
...grin like a chimp
S2000 GT - gone
- exocet
Re: M Sport Button
BMWZ4MC wrote:Absolutely! Out of sport mode, the throttle does almost nothing for the initial part of its travel.Aliv6 wrote:I use it everyday! BMW's throttle response is horrific!!!!!
We should not talk about the same Z4M model .
Z4MC Interlagos Blau
Re: M Sport Button
In my E46 M3, I found the M switch much too sensitive for daily use, although it was pefect on the track.
it was great when letting friends drive it! They were invarably like, Man! this thing has soo much power!!
Looking for a White on Sepang Z4 ///M
In the garage: 700 HP/TQ 2002 911 equipped with a little Turbonium
- khooni
Re: M Sport Button
exocet wrote:BMWZ4MC wrote:Absolutely! Out of sport mode, the throttle does almost nothing for the initial part of its travel.Aliv6 wrote:I use it everyday! BMW's throttle response is horrific!!!!!
perhaps his throttle sensor got out of tune. lol
- BMWZ4MC
Re: M Sport Button
...Or maybe I have delicate feet...
S2000 GT - gone
- ChawenHalo
Re: M Sport Button
Keep your knickers on. To ask why put a useless button in an otherwise pretty uncompromising car. Would have made sense to hold off the ESP further/ change engine mapping etc.MyNamesNotBob wrote:Why? To ask why the button doesn't do more? It changes the input required on the throttle for the throttle position at the engine end.ChawenHalo wrote:I wish we had an M engineer on this forum.
- ChawenHalo
Re: M Sport Button
+1 ouch.BMWZ4MC wrote:...Or maybe I have delicate feet...
I'm going to turn that button into missile launch...or to me coffee.
- ga41
Re: M Sport Button
Like your thinking! One press and a nice frothy cup of fredo cappuccino pops out.ChawenHalo wrote:+1 ouch.BMWZ4MC wrote:...Or maybe I have delicate feet...
-- http://www.freerice.com/ For each answer you get right, they will donate 10 grains of rice to the United Nations World Food Program --
- Franzino
Re: M Sport Button
Same here... When pressing the sport button nothing happens. When I release the throttle and press it again I feel a small difference is throttle response (that's it).mmm-five wrote:I never get that, and have to release the throttle slightly and reapply to get any effect.Adam D wrote:Yeah hold a constant throttle on and press it... might get a bit of acceleration as it magnifies the input from the throttle to be less proportional.
However when I switch off the sport mode the engine revs drop instantly and the car slows slightly.
