Guys,
Since the upgrade I can't browse the site on my ipad, was working fine before. Have cleared cookies, cache etc but no change.
Using the normal Safari browser not the iPad app.
HELP
Not working on my iPad
Re: Not working on my iPad
Working on mine, but seems much slower than usual (using Safari & Atomic)
- playalistic
You probably need to flush the DNS as changes were made to the site over the weekend.
Tap Setting > General > Reset, then tap Reset Network Settings.
- pvr
That does not work either, the only way I can get on the site is to use the Google DNS settings of 8.8.8.8
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
You can also supposedly turn 'airplane mode' to on and then to off again to do the same thing without resetting any saved network configurations (VPN, proxy, etc.)
- playalistic
If that doesn't work your regular DNS isn't playing by the book or your router/switch/hub etc is caching DNS records and not honouring the TTL.
- pvr
It is working fine on a Macbook with Safari.
Windows PC on the same router with Firefox does not work. Have not tried IE though.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- AGDelaney
I have had same problems. Using Tapatalk and Safari I couldn't access forum at all. Has now started working over O2 3G. But doesn't work over O2 broadband. Should it take this long for all DNS to be updated? Seems incredible.
Dns can take upto 72 hours to propogate around the internet. I could get to it on my pc but not ipad and they both use the same router / dns.
However have come home tonight and seems to be working ok now.
