Clay Bar Question
Clay Bar Question
OK, so I'm waiting for a nice day to crack open the new kit;
Spray detailer, Clay Bar and a DA polisher + pads N two grades of polish/cream.
My first question is, the clay bar, which presumably picks up all the crap from the paintwork after I've washed the car down. Do you fold this over after each panel etc? Because I'm concerned that the crap it picks up, might result in scratches as I go. Equally, can I also assume that you simply bin the clay bar after you've done the car given it will be full of crap by then?
I want to be sure I get that step right, get as much off the car as I can without doing further damage before I break out the DA.
- Turbokid
Clay Bar Question
You should fold and nead the clay as you go, you need to keep it warm to keep it supple. Depends how dirty it gets, if you fold and cant reveal a clean part then use it for wheels instead or bin it. If you drop it bin it don't try and use it.
- Half Colin
Re: Clay Bar Question
There's lots of guides on Tinternet basically keep it well lubricated, keep folding it and most importantly if you drop it throw it away!
Now E92 330D M Sport, Sapphire Black, AC Schnitzers and carbon badges soon
Sold E86 3.0si Sport, Sapphire Black, AC Schnitzers, carbon badges, ZHP, stubby and NO RUNFLATS!
Thanks for the info (and link) guys, lets hope the weather stays nice
- VvrooomM
Clay Bar Question
If you drop it you can cut it like mouldy cheese!!
Tapatalking on my iPhone.......
Z4MC midnight blue with CSL's + VREDs, extd light sepang leather, folding mirrors, stubby aerial, retro bluetooth, prof nav, intravee ipod kit, storage and cup holders!!, laser LRC100, DSP hi-fi, storage and privacy.....is that it?
- Z4 Coupe
The first time you do clay a car it's amazing how much crap comes off on to your clay!
I do my windscreen too as it keeps the wipers from squeaking.
- Turbokid
Clay Bar Question
[quote="VvrooomM"]If you drop it you can cut it like mouldy cheese!!
Dont do this you WILL regret trying to re-use it.
- VvrooomM
Clay Bar Question
don't see the issue, you are removing the contaminated surface.Turbokid wrote:VvrooomM wrote:If you drop it you can cut it like mouldy cheese!!
- Turbokid
Clay Bar Question
don't see the issue, you are removing the contaminated surface.VvrooomM wrote:Turbokid wrote:VvrooomM wrote:If you drop it you can cut it like mouldy cheese!!
Try it and find out then!
- Z4 Coupe
Clay Bar Question
I always split mine into at least two pieces. That way if you drop one you're less likely to try and reuse it and just use the other piece.
- Half Colin
x 2Z4 Coupe wrote:I always split mine into at least two pieces. That way if you drop one you're less likely to try and reuse it and just use the other piece.
There's no reason why you couldn't remove the contaminated surface if you drop it but is it really worth the risk? If you don't manage to remove all the contamination you'll only find out after you've used it again and scratched your paintwork to hell!
Nah, not worth the risk - drop it then bin it.
- Biggsy
Will claying remove tar specks?
what spray should i use with it?
Alpine white 2011 S23 M SPORT,
- Turbokid
Clay Bar Question
Yes, you can get different grades of clay depending on the level of contaminants you need to remove.
There are many different clay lubes on the market but I use Meguires Last Touch as it can also be used as a drying aid.
- Z4 Coupe
Clay should remove tar specks but if it's just tar you're after something like this might be quite good?
http://www.cleanyourcar.co.uk/engine-an ... d_105.html
If you've not got a clay bar you could get a kit which has the clay and lube. Something of this page would be fine.
http://www.cleanyourcar.co.uk/detailing-clay/cat_9.html
The beauty of clay is the paint will feel like glass afterwards
- Turbokid
Clay Bar Question
The best alternative to clay for removing tar is Tardis, but it's a solvent so I recommend the caution be taken when using it!
