replacing headlight seals /rear covers
[*]hello i have the condensation look on my headlights i have ordered men seals and recs covers at 25 squid . is there a guide onimy to replace them .. does the wing have to come off ?!
- RJS-Z4
Re: replacing headlight seals /rear covers
Not the wing, just the front bumper. Then they just unbolt and unplug.
Titanium Silver E85 Mods Done - 224's, Stubby, Amarone //M seats, ZHP, Retrofitted Wind Deflector, Aux In
- Bing
You don't need to take the bumper off if you are talking about the rear covers for the headlights - you just need to get in to top access hatch in the wheel arch.
Turn the wheels so the wheel on the side you want to replace is facing out (not in - counterintuitive, but gives more space)
Use a 10p to turn the catches on the hatch and pull it out
You will see a piece of wire diagonally over the headlight back hooked at the top closest to you and the bottom on the other side
Pull the wire down, out of the clips it sits in, then pull the old back out
To fit the new one do the reverse. I find it easier to take the far end of the wire out of the hole it is slotted into and put it back in when the back is in place (wire just gets in the way otherwise). Also, you do need to wiggle and lever the back about a bit to force it into place.
Check the bonnet is securely fastened when you are done - the cable to release the side catch is close to the headlight and the procedure can put enough pressure on it to pop one side one.
Hope that helps - sorry I don't have any pics, but it is pretty straightforward.
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- RJS-Z4
Sorry Bing, I assumed the original poster would want to remove his and dry them out.
- Bing
For that you just need 20mins and a hair dryer. Takes me 25mins as I have to get mine from in the house rather than the bootRJS-Z4 wrote:Sorry Bing, I assumed the original poster would want to remove his and dry them out.
i do not have enough hair for a dryer... i've ordered some silica gel packs
- Bing
Me either - I use the wife's, much to her disgustbadflaw wrote:i do not have enough hair for a dryer... i've ordered some silica gel packs
so.........
put the new seals on. left silica gels in for a day or so
all sorted and it hasnt come back.
its a bit fiddly but not too bad... access the lights from the flap on inner wing by the wheel
- RJS-Z4
Nice job
- vanilla
hmm..I need to do this - also my bonnet release cable is stuck, Bing, you said the latch is close to the headlight?
2.0 SE Z4 Roadster Sapphire Black, Red Leather.
MM gear knob.
R. I. P
MM gear knob.
R. I. P
Yes they are in there there some where to the inside edge of each light. I found it by mistake when doing this job on my passenger light and if popped the bonnet. But it just does one catch. I assume the other catch is a separate wire perhaps even only accessible from the other light - that bit needs to be confirmedvanilla wrote:hmm..I need to do this - also my bonnet release cable is stuck, Bing, you said the latch is close to the headlight?
Z4MC | Midnight Blue | OEM CSL's + MPSS | Extended Light Sepang Leather | Folding Mirrors | Stubby| BT | Prof Nav | DSP HiFi | Intravee | Privacy | Illuminated ZHP…
- vanilla
Thanks, could you describe what it looks like a bit more please? so if i 'fiddle' with it, it might free the bonnet again?jamiez wrote:Yes they are in there there some where to the inside edge of each light. I found it by mistake when doing this job on my passenger light and if popped the bonnet. But it just does one catch. I assume the other catch is a separate wire perhaps even only accessible from the other light - that bit needs to be confirmedvanilla wrote:hmm..I need to do this - also my bonnet release cable is stuck, Bing, you said the latch is close to the headlight?
MM gear knob.
R. I. P
MM gear knob.
R. I. P
