Carver DSP - Poor sub volume
Hi I'm looking to solve the same issue I think.
My car has the pro hi fi with DSP options on the nav screen. However the sound quality is generally poor and there is hardly any bass at all. You can hear some very low frequency stuff when fading to rear, but in general all sub output sounds wooly and out of phase.
Are there some visual checks to do? Also is there a knack to opening the fuse box I can see behind the glove box?
Z4 M Coupe, Lotus Elise and a daily diesel
Mine is currently with a specialist who is running some checks. Debating whether to add an extra amp and swap the carver subs for some 8" shallow mount alternatives...
In your opinion is the carver set up any good when it is working properly?
I think it is good, but just a shame that the behind-seat subs don't seem to do anything...
- DMike
Could fading to rear channels be part of the issue? The carvers are fed from the front channels.
2005 Z4 3.0i Sterling grey
Think they have a dedicated sub channel which is independent of the fader settings.
Had a look around my car this evening and found the Lear amp. Also found an Alpine KCA-420i (the cd changer had been removed and replaced with an iPod lead but I wasn't sure what it was connected to until now.)
Couldn't find much online regarding replacement amps - what do you guys do? Repair or go aftermarket?
On the intravee site it mentions needing the above with an Intravee II for iPod - I couldn't see any other box in there so guess you don't really need both and the Alpine box simply replaces the changer.
EDIT - Just found an intravee 2 tucked away in there too!
Scaramanga did you have any luck with the specialist?
I took the grilles off the subs and found them to be working, and also that they are unaffected by the front/rear fader setting.
But still, most of the audible bass is coming from the front.
Currently away on holiday but he said that the signal was much better if he tapped into the front woofer channel.Lofty wrote:Scaramanga did you have any luck with the specialist?
I'm not necessarily keen on that as I would prefer to keep as stock as possible. Thinking of replacing the rears with 8" subs driven by a dedicated amp.
Onlinethecremeegg
I had the same issue - no bass even though it was turned up. I turned the bass slider all the way down then back up again and that fixed it!
Z4M - Interlagos Blue with Black Leather
Z4 3.0i - Sapphire Black with Red Leather - FOR SALE!
I found part of the problem with the sound on mine.
If I use a simple AUX in the sound is pretty clear, and even the bass sounds fine. The lead I have can't maintain a decent connection though which is annoying.
It's when I use the iPod kit that the sounds goes to sh!t!
The bass sounds out of phase, woofly and distorted, and the rest of the range sounds poor too, with a little distortion.
I am using an iPhone 6s with an apple lightning converter. (And of course doesn't charge either).
So I'm wondering if it is a limit of the iPod kit hardware or if it's faulty
Limit of the kit I imagine.Lofty wrote:I found part of the problem with the sound on mine.
I'm in the process of upgrading the DSP Carver in my system as the head unit was out of date 13 years ago never mind today. New head unit which means new amp needed too and 3 way crossovers and new wiring to handle the new amps load.
Costing me about £1K when you include installation costs too. I however will be looking to sell the old kit to recoup some of that.
Scaramanga, how are the rear woofer speakers sounding now that they were tappped into the fronts? I get nothing out of the rears and it just pisses me off! I have tried everything I can and was thinking of going this route if it works. Crazy to have a couple good looking speakers there and no getting any sound. From what I have read they are identical speakers as the ones in the lower front, and I think they do a great job! Let me know if it is worth the trouble....Scaramanga wrote: ↑Wed Apr 06, 2016 8:18 pmCurrently away on holiday but he said that the signal was much better if he tapped into the front woofer channel.Lofty wrote:Scaramanga did you have any luck with the specialist?
