Squeaky Brakes
- JayD
Squeaky Brakes
Plenty of life left in the pads, doesnt squeak under hard braking, only when crawling along really and then light pressure to stop the car.
Anyone else had this?
Jay
Jay
Onlinesp3ctre
- Site Admin
I had it on the stock pads... only when crawling veeeery sloooowwwly.... I have since swapped to Axxis pads, and bedded them in properly and don't get any noise at all.
- cj10jeeper
Yes - had this problem so many times over the years on cars
Usually traced it down to 1 of 2 things
Pads becoming glazed or not bedded in properly
Broken pad retainers/springs or not bonded to caliper as appropriate.
Happens on the Z4 each time I wash it so that's just surface rust. On X5 cured only after fitting new pads (Axxis) as mentioned above as it happens
Your friendly local auto parts store sells a special type of lubricant that is designed to alleviate this problem. Before you jump off the deep end, this is a compound you apply between the shims on the backside of the brake pad - not the business side of the pad.
Most of the squealing you hear are vibrations between the pad backing and the pots on the caliper and the anti squeal compound helps dissipate that.
2007 Z4 3.0si Coupe - Silver Gray, Black Extended Leather, Dark Birch trim
Premium pkg, Sports Pkg, M seats, Clear Bra, Heated seats, NAV, DICE, Michelin Pilot Sport PS2s
- JayD
Thanks Alan, I will have a look out for some of this. It isnt bad just annoying more than anything.AlanL wrote:Your friendly local auto parts store sells a special type of lubricant that is designed to alleviate this problem. Before you jump off the deep end, this is a compound you apply between the shims on the backside of the brake pad - not the business side of the pad.
- Yal
I once had a friend tell me exactly that. But he kept insisting that it wasn't a noise, it was a vibration. I kept telling him that it was a noise. We went back and forth for about 5 minutes with him getting more and more frustrated when I finally told him that you couldn't have a noise without a vibration. To this day, I don't think he understands my point.AlanL wrote: Most of the squealing you hear are vibrations between the pad backing and the pots on the caliper and the anti squeal compound helps dissipate that.
I love to pick the most stupid point and argue passionately about it.
Yal wrote: I once had a friend tell me exactly that. But he kept insisting that it wasn't a noise, it was a vibration. I kept telling him that it was a noise. We went back and forth for about 5 minutes with him getting more and more frustrated when I finally told him that you couldn't have a noise without a vibration. To this day, I don't think he understands my point.
- BMW^Z4
I had squeaking after my first track day. We really cooked the brakes that day and my buddy made the mistake of leaving his foot on the brakes after we came to a stop. Result: the discs bear a nice outline of the pads.
Anyway, I think we glazed a part of the disc and ever since then they start squeaking in stop-start traffic.
