Earlier I removed the boot carpet to find the pass key located on the bluetooth unit.
Thinking back, further along that same back wall, right of centre, half way up was a cable and connector heading in to the car.
Would this be the fabled CD changer connection (as I have that unit in the centre console)?
Sent from my GT-I9300 using Tapatalk 4
Was that the CD changer cable?
- Dog Biscuit
3.0i SE Sterling / Black, Go Faster (Sport) Button, M Sport seats, 107s, Xenons, Dice Mediabridge 1500, MFSW, Cruise, Bluetooth, DSP, LEDs etc...
- Stuart Truman
Re: Was that the CD changer cable?
You'd need to find two connectors, one for the iBus and one for the audio. Depending upon the age and whether you have DSP it's possible that one will be a co-axial cable (although I've only ever seen a normal wire connection)
The cables normally come out of the main wiring bundle close to the centre.
Add yourself to the Z4 Map HERE! Instructions HERE!
Z4M Roadster, Imola Red, with Stubby and Intravee II. Low Miles per Gallon, High Smiles per Gallon
Previously Alpina Roadster S #69 Alpina Blue
- Dog Biscuit
Thanks Stuart - am familiarising myself with the carStuart Truman wrote:You'd need to find two connectors, one for the iBus and one for the audio. Depending upon the age and whether you have DSP it's possible that one will be a co-axial cable (although I've only ever seen a normal wire connection)
