Just wondering if these would fit a 3.0si coupe, it's lowered on eibach springs.
I presume the front would be fine but would 9.5" wheels on the back be a problem?
http://www.ebay.de/itm/Alufelgen-BBS-CK ... 25731fcac8
Would these fit? BBS CK
Re: Would these fit? BBS CK
Anyone know?
- GP06Roadster
Fronts ok. Low rear offset means they will poke out 1.3mm at the rear more than a 224 or in other words they will stick out a little outside of the rear arch
E86 3.0si Manual
That's a pity, such nice wheels. Thanks for confirming.GP06Roadster wrote:Fronts ok. Low rear offset means they will poke out 1.3mm at the rear more than a 224 or in other words they will stick out a little outside of the rear arch
- LukeMace
They will be fine!
I'm running 19" 9.5 wide ET27 lowered on FK springs (lower than eibach springs) and they run fine!
The wheels here are 18" and ET 35 and on eibachs should be absolutely fine. I'd run a either a 265 or probably a 255 tyre on them
3.0, Quad Conversion, 19" CSLs, Bucket Seats, Big Brake Conversion, Lowered 40mm, AE and Clear Hockeys etc...
CLICK HERE FOR THE BUILD THREAD
So they will definitely fit with no rubbing? I was going to use oe size tyres, 225's up front and 255's rear.LukeMace wrote:They will be fine!
