Phones that are compatible/incompatible with BMW Bluetooth
Breaker
Re: Phones that are compatible/incompatible with BMW Bluetooth
Post by Breaker » Mon Mar 31, 2008 4:16 pm
sapphire_nick wrote:I should say, I don't get SMS on my iphone, should I?
Not that it bothers me to be honest!
Breaker, have you asked Bimmernav if they can get you a cradle for the KRZR? May require a modded eject box?
Yes I have asked and they don't do a cradle for the K1. Works just fine having the phone in my pocket. Even worked well with the phone in a bag in the rear boot/trunk! :thumbsup:
3.0si Z4 Coupe then an sDrive 35i Z4. Great cars, now gone. Range Rover Evoque owner now! :)
gannet
Post by gannet » Mon Mar 31, 2008 4:40 pm
the module is in the boot so the phone should work fine in the boot :driving:
-- Gannet.
Current: MINI JCW... - Modification: Driver Upgraded :D
Previous: DS3 DSport, Z4 3.0SE, 206 GTi & XS, Alfa 147 Lusso
Mattt
Post by Mattt » Tue Jun 24, 2008 6:39 pm
Nope, I've never seen a phone that works with SMS on the Z4!
The previous owner of my car managed it, and I had all their texts! ;)
cj10jeeper
Post by cj10jeeper » Tue Jun 24, 2008 8:16 pm
gannet wrote:the module is in the boot so the phone should work fine in the boot :driving:
It's more dependant upon where the bluetooth antennae is. The standard mounting point is on the housing for the SatNav/DVD high up between the seats. In reality the range is so great they will work anywhere in or near the car. Mine even picks up the phone in the house when the car is sat in the drive some distance off. :)
Mattt
Post by Mattt » Wed Jun 25, 2008 1:58 am
My bluetooth doesn't work at the moment, but it still pairs. I had to make a call earlier, and had to run about 20 feet from the car to disconnect the bluetooth!
baugelli
Post by baugelli » Wed Jun 25, 2008 3:54 pm
Mattt wrote:My bluetooth doesn't work at the moment, but it still pairs!
What part doesn't work? It pairs and you just can't send/receive calls?
Envy: 2005 Olivine Green/Beige Z4 3.0i Roadster with Premium, Sport, Xenons.
Deatte: 2008 Alpine White/Beige Z4 3.0si Roadster with Premium, Sport, Xenons.
Sabine: 2015 Alpine White 328i M-Sport Sedan with Premium, Adaptive M-Suspension, Xenons.
Mattt
Post by Mattt » Wed Jun 25, 2008 4:26 pm
It pairs, and I used to be able to use it for the speaker/mic, I still had to answer/dial on the phone though. Now it says it has answered the call, but I get no sound through the car or headset.
Zedster
Post by Zedster » Wed Aug 06, 2008 12:20 pm
Hi
Just looking at the compatable phone listing. My SonyEricsson K800I does not have SMS but otherwise fully compatable. Just wondered if any other forum members have the same problem?
SI Coupe Silver Grey
davidpfitz
Post by davidpfitz » Wed Aug 06, 2008 10:59 pm
Almost no phone works with SMS - don't let it put you off buying the phone!
Breaker
Post by Breaker » Fri Aug 08, 2008 9:31 pm
Just got the new Samsung Tocco phone and it works well with the OEM bluetooth. :thumbsup: Still no texts though.
Great touch screen phone also! Saves having to get an iPhone and change to O2!! :D
DELBOY
Post by DELBOY » Thu Nov 19, 2009 9:30 pm
The BMW phone compatibility list indicates limited compatibilty with N95 phones, and I'm led to believe, most of the "N" series. My N95 would "pair" enabling the receipt of incoming calls, but would not allow my contacts to be "exported" to the car. After a little research and much tinkering I've managed to add all my contacts to the car database. Should anyone else be having problems adding "phonebook contacts" to the car when "pairing" Nokia "N" series phones, this is the solution that worked for me.
1. Delete all Z4 pairings on phone, and any N95 pairings from the car
2. Reset phone by turning phone OFF and ON again
3. Download Nokia 810 Contact Download Application.
DL 810 here-> http://europe.nokia.com/get-support...ia-810/software
4. Install the app to your phone using Nokia PC Suite and ignore any messages saying it's not compatible.
5. Select new app on phone and configure to always start on phone start
6. Turn off phone, go to car,
7. Turn on ignition, turn on phone
8. Commence bluetooth pairing as per the handbook, and complete the pairing, enter pin and accept, leave ignition key in position one (the downloaded app left still running on your phone)
9. Go to "Contacts", "Mark All" or whatever you wish, then "options" . . . ."send business card" . . . .via "bluetooth", hey presto "success" turn off ignition, turn back on, press RT button to view your contacts and smile contendedly to oneself : )
(Credit for most of the procedure is due to unknown persons on other obscure BMW forums . . .well done to them and thanks)
Delboy : )
2014 Z4 sDrive 35is
petach
Post by petach » Thu Mar 04, 2010 9:40 pm
SPV 3100 (is it an HTC?) works and shows phone book.
Live FAST.....die when you can fit it into your busy schedule!
Entwistlea
Post by Entwistlea » Sun Mar 07, 2010 5:30 pm
My new Nokia 6600i doesn;t work properly, constantly dropping and when you get a call the car just carries on ringing even though the phone is "answered"...... Old E66 works a treat tho, so back to the old phone.....
'07 Z4MC / '07 MX-5 / '91 MX-5 track day special / '95 Hiace SC
petach
Post by petach » Sun Mar 07, 2010 7:45 pm
Nokia 6310i works on 2003 model, displays SIM directory. So does SPV 3100
petach
Post by petach » Tue Mar 16, 2010 8:52 pm
The issue I have (as I understand it) is that there are few (if any) snap in adapters for modern 3g phones that fit my 2003 Zed. For instance, the E71 snap in does not fit my cradle. The previous owner had a Nokia 6310i, but this is not 3g capable. I am reduced to call forwarding from my "Three" E71 to the "Orange" 6310i. A bit of a faff forwarding on, forwarding off.....on.....off.....each time you get in or leave the car............aaargh! Of course I could just leave the phone on the seat or whatever, but I wanted it out of the way, charging in the cradle supplied between the seats
