G-Sensor / Yor Sensor Problem
Hiya,
Do any of you have any experience with dealing with a possible fault with the g-sensor/yor sensor unit please.
My zed has failed the mot on a light on the dash - garage think its this unit which is located under drivers seat, under the carpet which was wet due to a seal not sealing (now sorted) but it must already have had some water under there which I didn't know about.
Can these units be re-furbed or reset as they are £400 plus vat from dealer or is it deemed dead already. If this isn't the problem, dealer say the unit cannot be returned so a bit stuck either way really (
Thanks for any help
Gill
Thanks for any help
Gill
Re: G-Sensor / Yor Sensor Problem
Is there no one here who can shed any light on this please.
Zed now passed but would like some info if possible on this unit\sensor
Gill
Gill
- RickRob
[quote="
Gill[/quote]
I assume that this is not a wife-related question??
Gill[/quote]
///M Roadster. 2007 Black/Black. Rear spoiler, whippy aerial, mud flaps and gimp-style wind deflector!
I have this problem lateral sensor an amber handbrake light lit
I have seen this before in other threads.
The sensor gets wet and dies and needs to be replaced.
Yeah my passenger side carpet was wet. How was your issue sorted for MOT?
Hi, the part had to be ordered from BMW which took a week and replaced it along with the sensor in the 'b' pillar.
It seems to be a sealed unit so not sure how it got moisture inside to ruin it. This sorted the fault and now have the mot., but those two parts alone were over £500. Aparently bmw said they had sold 60 of these sensors in 12 months and a 1000 of the sensors which go in the pillar.
Apparently it comes in to action when the zed is Driven with a lot of enthusiasm , as in track day enthusiasm.
sniffer wrote:I have seen this before in other threads.
Can you point me in the direction of the other threads if possible please,I would like to see if I can find out more about this, thanks
Gill
- mac27040
If it's the sbsl airbag module I have a brand new one for sale £75 + p&p
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
Hi, mine was the osr wheel sensor which was being picked up as a fault, looked like an exclamation mark inside two brackets on the dash.
Yeah when i let the handbrake off, my handbrake light turns feom red to amber, and stays lit. Also i noticed my hill assist has stopped working, even though the bmw specialist i use insist it never had it and was never fitted to these models
I replaced mine about 2 months ago. Took about 1hr. Basically remove the drivers seat, lift the carpet up, undo the electrical connection undo 3 bolts if I remember correctly put new one in then everything goes back. Just remember to disconnect battery.
Got the part off ebay for around £30.
That's it plug and play - light goes off itself.
Use shipkillers guide for seat removal.
savings circa £500.
savings circa £500.
Z4 3.0i Auto Black Sapphire - Dream Red Oregon - Wind Deflector/Isofix/Seat Heating/Xenon/TV/BT/Prof Carver/Elec Fold Ext Mirrors/Grad Tint WindScreen/Auto Dim Int & Ext/ Storage Comp Pack/PDC/CC/Nav Sys Prof/6 CD Changer/DDC/Chrome Line Int etc etc
garage reckon they need half a day to rip interior out lol So its definitely under the drivers seat then?? is it called the lateral sensor?
Yes it's there. Forgot to mention that when you take out the drivers seat you have to pull up the trim near the door so that it releases the carpet. The carpet does not come out fully you just work under it. In the end I proped up the carpet and left it for half a day to dry out it was one of those really hot days.
It is called a Yaw Sensor or Speed Sensor or Sensor Clustor (this last is actually written on it). The one I used was part number 34526759412. You can use one from various cars - e46, mini etc - sourced from ebay.
The topic that was most helpful was - http://www.z4-forum.com/forum/viewtopic ... 1&start=15
