Unleaded or Super
Unleaded or Super
Hi
Ok its time to fill y tank for the first time
As a new owner I want to look after my little coupe, so what should I put in ? I am more interested in what is the best for the engine rather than power gains.
Engine is 3.0 N52
Super Unleaded.
Unleaded.
Alternate between both.
Or does not make any difference.
Gaz
Engine is 3.0 N52
Super Unleaded.
Unleaded.
Gaz
- nfbr
Re: Unleaded or Super
Technically speaking your engine is equipped with what it needs to adapt to either fuel and there isn't really one better than the other.
A higher octane fuel simply will allow you to get the best out of the engine allowing the ignition timing to be run more advanced without knock (I.e. free power)
A lower octane fuel will be seen by the knock sensor which will retard the timing slightly so it won't feel quite as crisp, but this won't do the engine any harm.
In general, higher octane fuels give a slightly better mileage return, so despite being more expensive, it'll probably work out somewhere similar when measured up as pence per mile.
nfbr's 2007 BMW Z4 3.0si Sport Coupé - Car Diary/Blog/Build Thread
Ruby Black - Steptronic - Champagne Merino leather.
I like taking Photos, Cars, Technology and Rock Music
I run everything on super inc the mower
2007 Z4 ///M Roadster, Black Sapphire, Nav, Deflector, Eibach's, Bilstein B6's, OEM CSL's 6 Pot BMW Performance Calipers
Hi Gaz,
I use 99 Ron. I also have the N52 3.0.
People on here run on all types of fuel (supermarket 95, 99, v power etc.) and report good performance. I only use 99 Ron as the particular fuel 'claims' to have the most detergents to keep everything clean in the engine (Shell V Power Nitro).
I do so few miles that the cost difference is minimal, esp as I take the car out each week, and the Shell garage is on a nice drive from my house. Win win. It could all be advertising hype. But when I filled up my tank for the first few times with v power, I definitely noticed the idle getting smoother over the first few hundred miles.
I was in a similar situation to you, I had just picked up a lovely silver grey Z4 coupe. Great looking car. Enjoy!
- Terryvision
This has been discussed before in many posts in detail..
viewtopic.php?f=2&t=20487
Do a search gazoff, you will find that the answer is ..... "its your car and you put in what you think is best for it"
- Ewazix
I know the weather probably makes as much difference as the RON rating but I still use V Power, I've had a tiny hint of the the 'tinkles' under load (pinking) if I use cheapo fuel and the V Power gives an extra mpg or two so it evens out as others have said. Try a couple of consecutive tanks of both and see what you think or if you can tell the difference particularly at idle or foot down under load up a hill.
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- Bing
I used normal unleaded in my 3.0, no issues at all. Mainly for reasons of cost. I did try a few tanks of v-power back to back but tbh didn't really notice a difference, IIRC. I use v-power only in my current car because of what it is, and it's only ever been fed v-power. Given the way petrol prices have dropped of late cost is less of an issue now I guess.
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- Dewi
Personally I run mine on 98 RON as that is the first suggestion in the owner's handbook, and the key here for me is that it states, "The engine of your BMW is *designed* to run on superplus / premium plus petrol, octane number 98 RON" followed by "You can *also* run the engine on premium grade unleaded petrol, octane number 95 RON". I take that to mean the preference is for 98 but you can use 95 if you have to.
The bike (also a BMW) runs on super unleaded too, but mainly because it runs like a bag of spanners on anything less, it lacks power and vibes really badly. The car, I only ever ran on 95 unleaded once and it ran ok but I did notice over the tankful there was a decrease of a couple of MPG over the Super unleaded.
Bottom line: your car your choice.
Hasn't there been some suggestion on the forum that 98 Ron has led to warning lights through over sensitive sensors?
Someone tell me different as I don't want to be alarmist. . . .
- JayEmm
I would be surprised if it did seeing as 98 is exactly what BMW specify for their cars.paulgs1000 wrote:Hasn't there been some suggestion on the forum that 98 Ron has led to warning lights through over sensitive sensors?
If you check the manual or specs basically the car is designed/measured around using 98 RON fuel but it is perfectly capable of using 95 octane - and probably lower for short periods but it won't be happy.
This topic has been done umpteen times on many motoring forums. General consensus seems to be with a modern BMW there are definitely benefits to using Super - but they are subtle. Generally unless Super is much more money than regular then Super is all I will use.
James Martin - aka "JayEmm"
Director of Photography (Cameraman)
History: E46 M3 LSB, Z4 MC, '05 E46 330Ci Clubsport, 645Ci, '96 911 Targa, '99 911 C4
- Swiftly
I never put anything but Super in the tank, preferably Shell Ultimate or Tesco Momentum
- Adamski
Oh Lordy - a thread about Unleaded vs Super....
Allow me to be more helpful, with a few reading suggestions
viewtopic.php?f=2&t=12594
viewtopic.php?f=2&t=12463
viewtopic.php?f=2&t=73683
viewtopic.php?f=2&t=13459
viewtopic.php?f=2&t=54734
Gone: Z4M Coupé|Black Sapphire|OEM CSLs|Aero Skirts|OEM Strut Brace|Nav|Heated Seats|Logic 7 Pro Hi-fi|Bluetooth|Carbon Leather|PDC|BMW Assist|Stubby
Gone: Cherished 2003 3.0i Black Sapphire Roadster
- jan_tekin
I mix with mine but tend to use super a lot more then normal. I remember when i was in Germany last year and they had 102 Ron which I had to try it out
Current: M135i
Sold:3.0lsi Sport Roadster, Xenons,Heated seats, blutooth, Hi Fi,Comfort Pack, Cruse Control, Stormworks ST1
Gear Knob, Stubby, KW V2s, 224s
I don't think it makes much difference between premium or super but I personally always fill with super from Esso or Shell.
I have the 3ltr coupe too - once filled with Tesco Momentum - Now that did make a noticeable difference
