Very nice !cj10jeeper wrote:Managed to do this little project this afternoon, so a few photos of the change:
Does this mean that you now have a pair of original 3.0i carrier on your hands ?
Shooter wrote:Very nice !cj10jeeper wrote:Managed to do this little project this afternoon, so a few photos of the change:
I'm not in any rush, I have to check out what I have anyway. It should all be there but it's been over two years since I swapped it all so who knows! I'll let you know.Herminator wrote:I'd be interested Curtis, if I knew what I'll be doing with my Z4 in a couple of weeks
I bet someone here will be able to give you more for them than I would though, and sooner.
Yes - it would have. Other cars have slots in the rear cover plate, or exposed adjusters to work with. This is just devious.ZetaTre wrote:Isn't that the most absurb way to adjust a parkind brake??!!!
Well, the Z4 is actually MUCH MUCH easyer than the Z3: at least there is right-left cable equalizer. It took me a solid 3 hrs to fix the parking brake on the Z3 as it was keep pulling to one side or the other...
Maybe cutting a slot in the shield to gain access from the rear could have made it easyer...
Cool - glad you got it all doneShooter wrote:Done mine !
So, i got the brake carriers from cj10jeeper (thanks again, man !), originally from his 3.0i, then i got 300 mm slotted rotors from EBC and Redstuff pads, and everything just fit perfectly.
This setup still fits in the original 16" rims of the 2.5i.
Your right, they probably are not needed and probably a bit of overkill, but I was only looking at doing it as I need to change the discs anyway, and as I have the 2.5 which only has 284mm discs and to go to 300mm discs would still have meant new carriers, so I just thought lets go the whole hog if I can get the bits, easier said than done as I've now found out.Mr Whippy wrote:I honestly don't think the 325mm's are needed really, I wouldn't go after them unless you feel the 300mm's are lacking on good new pads/discs and fluid, lets put it that way.
I'm surprised the 300mm setup fit under 16" wheels though, I was after some of those as temp wheels locally for £100, would have done the trick but I didn't think they would fit, hey ho
