Rotor replacement HELP
zee42
Location: I could tell you,But then I'd have to kill you!!
Post by zee42 » Sun Aug 12, 2007 11:49 am
I'm replacing the stock rotors with Brembo drilled and slotted rotors.
no problems getting the wheels and calipers off,however there is a retaining screw on the rotor that must be removed before the rotor can come off.does anyone know if it is a torx or allen and what size? I need to get this tool before I can complete the Install
Wondermike
Moderator
Moderator
Post by Wondermike » Sun Aug 12, 2007 12:11 pm
RealOEM.com they call it an "Inner Hex Bolt" M8 x 14 so an 8mm Allen key should get it out I would have thought.
zee42
Post by zee42 » Sun Aug 12, 2007 6:33 pm
thanks,I'll give it a go :thumbsup:
