Sgr74
Post by Sgr74 » Sat Nov 04, 2017 4:56 pm
bz4kev wrote: Tue Oct 31, 2017 7:49 pm New stuff arrives tomorrow new suplex rear springs and seat belt guides for my m3 E46 seats FF857ABC-BDF0-47E6-B451-4F82B27EF0C0.png08DD1522-086C-4F31-B482-F39B92845D46.jpeg
Do the seatbelt supports work?
I kind of want to push the belt away from my neck. I looked at these and dismissed them because the belt would still chafe on the neck.
Black 2.5 Roadie.
Coffee331
Post by Coffee331 » Sat Nov 04, 2017 5:45 pm
Fitted new drop links and anti roll bar bushes :thumbsup:
bz4kev
Post by bz4kev » Sat Nov 04, 2017 6:03 pm
Sgr74 wrote: Sat Nov 04, 2017 4:56 pm
to a degree helps keep belt from falling behind the seat but the belt can slip out a bit to easy when putting belt on only just fitted them so will let you know with regards to chaffing :)
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
DavesZed
Post by DavesZed » Sat Nov 04, 2017 9:09 pm
Snapped the brake bleed nipped in front drivers side caliper, last one to bleed ,totally pizzzd off,caliper off and hopefully drilled and tapped Monday fingers crossed.
DaveZ4richardson
Post by DaveZ4richardson » Sat Nov 04, 2017 9:15 pm
Had a spin around the Lakes today, no roof down though sadly, was a happy chap when a lady in the car park in Ambleside came across and asked what polish I used, she was very impressed with the shine and finish on the paintwork, makes all the hardwork worthwhile :D :thumbsup:
DaveZ4richardson :thumbsup:
3.0i 2003 E85 auto cruise control, smart top module.
rally-chris
Post by rally-chris » Mon Nov 06, 2017 3:43 pm
Private plates on, roof wrapped gloss black and missing headlamp washer cover painted (but not yet fitted).
On the downside, my engine check light has come back on again (lambda sensor fault) and I’ve got an exhaust related rattle just above idle - both a legacy of the recent Scorpion exhaust install!
Chris
08 Z4 3.0si Sport Coupe in Montego Blue
Ducklakeview
Post by Ducklakeview » Mon Nov 06, 2017 6:03 pm
Checked the rear discs for run out as could feel a little vibration on braking, they run out by 0.05mm or about. 002" which I presume is acceptable?
Mike
G600
Post by G600 » Mon Nov 06, 2017 7:07 pm
Ducklakeview wrote: Mon Nov 06, 2017 6:03 pm Checked the rear discs for run out as could feel a little vibration on braking, they run out by 0.05mm or about. 002" which I presume is acceptable?
Mike
That's fine especially measured that close to the edge.
E85 3.0
Ducklakeview
Post by Ducklakeview » Mon Nov 06, 2017 7:12 pm
G600 wrote: Mon Nov 06, 2017 7:07 pm
Mike
Fronts were even less, 0.02mm so the vibration is coming from elsewhere...
Mike
G600
Post by G600 » Mon Nov 06, 2017 7:22 pm
Ducklakeview wrote: Mon Nov 06, 2017 7:12 pm
Mike
Have you checked for variation in the disc thickness? The limit for that is only .01mm (E30 but I can't see it being different on an E85)
E85 3.0
MACK
Post by MACK » Mon Nov 06, 2017 7:31 pm
Mike
Mike
Have you checked your front rtab's?
Silver 05 3.0i SE
White E89 20i M Sport
Ducklakeview
Post by Ducklakeview » Mon Nov 06, 2017 7:36 pm
MACK wrote: Mon Nov 06, 2017 7:31 pm
Mike
Replaced 3 months ago. It's only a very slight vibration, but doing my head in.
Mike
bz4kev
Post by bz4kev » Mon Nov 06, 2017 8:00 pm
hi mate I would say not much different maybe a little more clearance but to be honest I only got them to stop the belt disappearing behind the seat and having to search for it behind me also think I will have to mod it some way to stop the belt slipping out of the clip but certainly better than it was :thumbsup:
MACK
Post by MACK » Mon Nov 06, 2017 8:13 pm
Mike
I guess it's a process of elimination then and checking the usual suspension components/ball joints etc. I'd probably start with the ball joints on the front arms
Silver 05 3.0i SE
Paulr
Post by Paulr » Mon Nov 06, 2017 10:19 pm
MACK wrote: Mon Nov 06, 2017 8:13 pm
Mike
Is it me, or does that disc look really worn? Should the lip be that deep?
If you try and take a cat apart the first thing you have is a non working cat.
