Nice ! Very nice !
- patriot66
Its dry and its sunny but cold, that can only mean one thing. Bring out the beast and lets drive.
DaveZ4richardson
3.0i 2003 E85 auto cruise control, smart top module.
- srhutch
- Moderator
Fixed the plunger under the bonnet. Took two attempts as the first one wouldn't fit back in the hole
Removed the good one and copied it.
3D printed a new cap and cut 1/2" off the spring as it was way too strong.
Just noticed in the picture they are different, so will have to replace now
- IMG-20171119-WA0012.jpeg (120.69 KiB) Viewed 1114 times
Cheers for thatmac27040 wrote: ↑Sat Nov 18, 2017 3:43 pmFind someone with DIS or Carly software to clear it, DIS is better at diagnostics than Carly but both should sort it.
Will give my good friend Swiftly a shout
'03 Titan Silver 3.0 auto. Hand controls, CC, MFSW CSL reps, H&R ARB's,
Now sold '03 Sterling grey 2.5 E85
- ph001
Gave it a nice clean and wax with Poorboys black hole and Bilt Hamber double speed wax...
- Phoenixboy
Can’t beat a gleaming black roadster
Took mine out for a good blast today.
Roads a bit manky in Devon today, so all washed and polished on my return.
E89 s drive 30i manual/gone
space grey
Carbon interior trim
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Gone, E85 Ruby Black.
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
- thanatu55
Third brake light hasn't been working for a while. I've been putting off looking at it because I couldn't be bothered messing around finding the right tools and removing the lamp again. Today I finally decided to tackle it, unscrewed the metal plate in the boot and it turns out I didn't need to remove the lamp at all. The wired connector had come loose, it was a bit fiddly but I was able to reach in and connect it back up without touching the lamp. I have a working third brake light again! And wow it's bright.
- 1000rr
New Simplex front springs anew ARB’s.
- Vornwend
Went for a top down spin in the sunshine , filled up with Super unleaded, removed the short piece of foam from the sound generator tube - quite pleased with that, just about the right level for me. Don't think it will help with fuel economy though
Now: 2004 Z4 3.0i - Merlot Red
Before: VW Corrado VR6 Storm - Classic Green
- mcbeee
I replaced another $80 angel eye bulb, what an absolute rip-off, I then ordered some LED's off the Net to give them a test,
Sold the Z4 M Roadster and a 911 Carrera S now I have a 2021 Z4 3.0i
- mr.tourette
Onlineronk
The cheque from the dvla comes thro very quickly these days! Mine went straight into my “car slush fund” were all little bits of shrapnel goes!
- Magicarcher
Z4 3.0L 2005. Titan Silver. Audio Upgrade Second Stereo Pioneer X8700DAB, Sony Xplode 4 x 70W Amp, 6.5" Reckhorn Subs in rear cubby, Focal AS165-3 in fronts.
- Magicarcher
- Remove the CDV and bled the clutch.
- Fixed my bonnet adjustment so that bonnet sits level with two wings and hopefully won't rub on radiator cowl.
- Drained, flushed and replaced the engine coolant
- Changed the air filter
- Changed the engine oil and filter
- Removed rear wheel arch liners and inspected, found small spot of surface rust, rubbed down, hammerite under-coated then Bilt Hamber UB waxed on top
- Brushed Bilt Hamber UB on rear brake pipe bends (where they always go rusty)
yesterday a stubby went on
and today was the first drive in the daylight! lively little scamp isnt it, though probably the cold temps and wet roads. sounds awesome, and the noise just builds as you approach the redline - 6k in a 3.0 straight six sounds epic! Not convinced by sport mode though... makes the throttle a little digital. like the weighty steering and ease of blipping the throttle. maybe it'll feel better when on track.
got brake pads ready to go in, and new rear track tyres on order, both of which should help with the grip. Will be taking the front camber pins off for as much front camber as possible as well.
