Water ingress from roof / windscreen seal.
Hi all,
Only had my 2010 30i Msport for two weeks. Was a bit disappointed this morning to find drips off water coming from the interior light surround and the mirror housing (where it attaches to the windscreeen.
There seems to be water inside the light housing which is slowly escaping.
I retracted the roof and checked the seals. They all seem to be in perfect condition and dry. The only other possible is the windscreen seal.
I have attached some images, but you have to look closely. This isnt a stream of water. Just drips. Irritating drips...
Anyone else had this?
Is it a known fault I can have sorted?
Nick
Nick
- IMG_2817.JPG (72.78 KiB) Viewed 1811 times
- IMG_2816.JPG (57.49 KiB) Viewed 1811 times
- IMG_2814.JPG (58.57 KiB) Viewed 1811 times
Black ext black int M sport 30i
- metal licker
Can't say I've seen another post with this problem,could it be condensation
718 4.0 GTS Boxster in YELLOW
718 Guards Red Boxster .........Gone!
A35 AMG saloon .........Gone!
JCW ...........Gone !
E89 35i Msport VO ................Gone !
E89 23i SE DSB ................Gone !
Hello to Jason Isaacs
Fingers crossed, that is all it is. It just seems odd, that it has been fine for the last two weeks, and suddenly appears after a heavy rainfall last night...
Nick
Nick
Put your roof up shagger.
You're welcome.
You're welcome.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Have you had the roof open when it's been wet, reason I ask is that a few weeks back I got a little over enthusiastic when cleaning my Z.
I opened the roof, wiped along the top of the windscreen then decided to lubricate the rubber with Gummi pfledge. Then for some unknown reason I thought why not spray some lubricating spray in and around the metal roof retaining holes in the top of the screen.
Looked in the car later to see that it had run through on to the rear of the sun visors and down the A posts!
Very embarrassing but live and learn
Cheers, Colin.
Cheers, Colin.
Hi,
Not since I first looked at it, that was in the rain. I would have thought it would have made its way out before now. It just seems a bit too coincidental for it to have chucked it down last night, and this morning I get drips.
It is coming out, on the corner joint, right next to the sos button.
More comes out when braking, which suggests there is a small puddle up there.
The garage I bought it from are having a look under warranty on Saturday.
Thanks.
Nick
Thanks.
Nick
- Silverzedtom
Sounds like it's a waiting game now your booked in.
Definatley worth getting a bottle of gummy pfledge to give all roof and door seals a good old lube.
I lube the seals once every other month just to make sure they're happy. A leaking roof is my 2nd biggest worry after vandalism, so wishing you a prompt fix!
E85 2.5si
F55 Cooper S
F55 Cooper S
I ordered some today having read about it on here. Looks like good stuff.
Thanks all.
Thanks all.
My windscreen seal had failed a few years ago but it took me ages to notice. Eventually, in the winter the car was icing up on the inside of the windscreen, and I was getting a few drips coming down off the rear view mirror. Not exactly the same as yours, but similar.
I took the car to BMW, and while I was going for a drive, an engineer was pressing the windscreen outward to the point that you could see daylight between the edge of the screen and the surround (eek!). Sadly, BMW wouldn't cover the seal under warranty but Auto Windscreens (very carefully) took the windscreen off and refitted it with a new seal - job done
10-plate E89 35i, Deep Sea Blue
67-plate F15 X5 35d, Space Grey
Thanks.
That sounds like the most likely cause.
It rained heavily last night, but not a drop this morning...
All a bit odd.
Nick
All a bit odd.
Nick
Further development.
It seems the seal on the original BMW windscreen has failed.
When they taped over the seal for the roof, water came in. When they taped over the windscreen edge, nothing came in.
I washed the car yesterday (by hand) then removed the internal trim and there was no water present at all.
It rained last night, and this morning, I found water all over the gearstick surround etc (see image)
They are planning to remove and replace the windscreen
I will let you know what happens.
- IMG_2843.JPG (87.21 KiB) Viewed 1620 times
Windscreen seal had failed. Screen out, renew seal, replace.
Waiting for the sealant to set overnight then will be tested again.
It was an original BMW screen and seal as well.
Hopefully now sorted and won't be raining in my car again...
- DMC63
Does the car have it's original windscreen? If not, then it could be a case of the new screen not having been fitted correctly...Maybe
BMW Z4 2003 2.5i and lots of bits and pieces - 2016 - 2020 Sold
It was and still will be an original BMW screen. The garage have never seen one fail and are amazed that an original screen seal has gone..
Being done tomorrow
Being done tomorrow
Turns out, that there was next to no sealant on the top edge of the windscreen. No wonder it leaked. The techs were horrified.
