Balls stupidity some may say they are closely linked!!
Monkey mans power adder
- Machine monkey
Thanks for letting me know. What brand of piggy back is it?
- Machine monkey
Perfect power smt8
- Machine monkey
But i drilled the holes for gauges. Had a slip and have managed to mark the facia. No problem I should be able to re finish it.
Still lots and lots to do.
Fitted and plumbed in the oil cooler, Oil cooler thermostat, In line filter, And the senders for the temp and pressure gauges.
]IMG_2882.JPG[/attachment]Still lots and lots to do.
- IMG_2885.JPG (57.12 KiB) Viewed 1198 times
- BMWZ4MC
Brilliant Glad you're actually doing this, its been a long time talked about in several of your previous posts. It all looks like really high quality work too - can't wait to see the end result
S2000 GT - gone
- mac27040
Machine Monkey car looking good but don't over do it otherwise it may resemble this
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
- Machine monkey
Yeah its more just get it working for now tidy things later. All the stuff in the boot will eventually be hidden by false floors. And the gauges might be moved. But like I say got to get it finished first. I can’t see me ever selling it. So i have lots of time to improve it once it’s working.
Although saying all that. I don’t want a show car look. More posh Mad Max.
- GuidoK
Interesting to see that you're going for the mishimoto thermostat.
Where did you get your oil cooler bypass from?
I'm almost done with fitting my s54 oil cooler housing. Most difficulties have been solved now (getting the output fittings to pass the supercharger drive snout) I only need to line up the bottom pulley now, so making some offset bushings on the lathe probably).
I'm using a much larger cooler though (19 row). Dont know if thats necessary though.
edit:
Oh wait, that oil cooler is mounted at the back! Took me some time to realize that
So that oil cooler+ thermostat is there to cool the oil return in case the turbo heats it up too much?
Is that necessary with those long lines? I assume the oil return goes directly to the sump?
edit:
- Machine monkey
The turbo has it own oil feed system completly separate from the engine oil. I still have to figure out an oil cooler fix for engine oil. One step at a time!!GuidoK wrote: ↑Tue Jun 13, 2017 2:58 pm Interesting to see that you're going for the mishimoto thermostat.
edit:
- GuidoK
So you also have a seperate oil reservoir and (electric?) pump?
Makes sense then indeed to monitor that pressure if something goes wrong.
And the cooler makes much more sense now too.
- Machine monkey
Yeah it snow balled 1 feed pump oil tank thermostat cooler filter 1 return pump pressure and temp gauges!!!
Would have been easier to run long lines!
- GuidoK
I think the m3 oil filter housing dropped recently in price from bmw with like 50% or so.
I recall it being about 400 quid new but now its half. Still expensive of course but not silly expensive and that may have its results on 2nd hand ones as well. (on ebay 2nd hand ones are still listed at about 200quid or more.... )
BMW probably had another batch made or so. I dont know if that effected quality of that they got it from a different OEM (original OEM is Knecht).
- Chris_D
Great to see two Z4 'top tinkerers' sharing ideas
- Machine monkey
Good to know they are cheaper now
I have an M54 housing waiting at a scrap yard I need to pick up. I was just going to give it a look over see what I can come up with. I might make a sandwich plate. Or a manifold and just run a oil relocation kit?
- Number5
Stop talking and get on with it Matthew
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
