Water ingress e89
Water ingress e89
In my case it was residual... and dried up after going around a roundabout for about 20 mins and mopping up the water that came out.
Water ingress e89
Thank you so much again!!!! Just out of interest did you ever find out where the original leak was?
Water ingress e89
The sealant under the top boot seal was brittle and water was coming in directly above the cubby hole. I put a picture in the other thread i linked for you. You can see the water dripping around the seal. Ive had a couple of e89s and both had that issue. However there are other leak points as you have found out too! Fingers crossed you've solved them all. The last thing you want to do is drown the electrics on the right hand side or submerge the roof pump..
Water ingress e89
Thank you so much! You have been really helpful.... Our boot seal had gone as well. Seems we are getting sorted thanks to you... Take good care xxx
- RobbiZ4
Water ingress e89
Correct. This process will take some time as the remaining water in the rails is swapping forth and back. If you keep the trims away, it will dry out over the next months, especially in the summer.
Keep care about the pumps foam and put it immediately into a plastic bag to avoid further contact with the remaining water.
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
Water ingress e89
Thank you so much for help
