Floormat Velcro
Floormat Velcro
Mine started coming away so I cut it off and ordered some online. Hook side stuck fine to mats but the loop side for the floor hasn't taken so well.
Anyone replaced theirs with something super strong?
Floormat Velcro
I stapled mine into the floor carpet the hook side n it's working well up To now
18 Z4s owned to date.
Current: 2.5i Titan silver
- RickRob
Floormat Velcro
I have this issue also. I can confirm that Evostik doesn't work.
I would be worried about stapling through electric cables!
///M Roadster. 2007 Black/Black. Rear spoiler, whippy aerial, mud flaps and gimp-style wind deflector!
Floormat Velcro
The carpet then the insulation foam underneath it is about an inch thick , trust me , you won't.
Floormat Velcro
I suppose what annoyed is mew mats font come with both sides and you cant buy the floor side separately.
I'll have a think about the staples!
- z4pilot
Floormat Velcro
Aftermarket mats tend to come with a plasterboard type screw to fix either a clip or Velcro to the carpet - wonder if you could adapt something similar?
Now Gone - 2008 Coupe, Montego Blue, Champagne leather and Piano Black interior, Eibachs & Koni Sport shocks, Style 230 19s, Eisenmann Quad - approaching perfection...
Floormat Velcro
All the aftermarket ones I've looked at seem to come with velcro too. I'd much prefer clips.
- z4pilot
Floormat Velcro
These kind of things?
https://www.amazon.co.uk/Teile-Floor-To ... B017J1S3BU
Floormat Velcro
Working on trying to figure a solution with these (just bourght some on ebay)- I believe there were used in E86
https://www.ebay.com/itm/BMW-4-OEM-Floo ... 2749.l2649
- s-l1600.jpg (241.71 KiB) Viewed 1172 times
Floormat Velcro
I've got them but the fuzzy side is needed. Still yet to find a glue to hold them on...
- 1000rr
Floormat Velcro
I used superglue to fix Velcro the the carpet. Works a treat!
- Stuartt
Floormat Velcro
Mine started to come away so I got a tin of contact adhesive from B&Q masked off the carpet around where they go applied the adhesive to both parts, let it go off then put them together and hey presto, looks factory like it never came off.
Stuart
Stuart
2004 3.0i SE Roadster , GONE to a good home
2010 e89 35i Sdrive M sport. GONE for salvage but has been reborn
2014 e89 35is M-Sport Design Pure Traction
Floormat Velcro
Not used in the Z4 but have used in old car and worked a treat with aftermarket mats.Scooba_Steve wrote: βMon May 15, 2017 10:32 pm Mine started coming away so I cut it off and ordered some online. Hook side stuck fine to mats but the loop side for the floor hasn't taken so well.
https://www.aliexpress.com/store/produc ... 14158.html
Alpina Roadster S LUX #030
Floormat Velcro
Here is the answer
51409947- buzyg
Floormat Velcro
I just glued my original Velcro back in place with some cheap, Home Essentials Super Strong Glue, from B&M.. Mind you I have used the same glue to repair my leather walking boots. Works on those too.
