Exhaust tips
- Udspie
Exhaust tips
Can anyone tell me how the exhaust tips are fitted to the back box. Are they just push on or is these some sort of fixing.
Tia
Tia
Z4 23i Roadster
- Nictrix
Exhaust tips
They are push on but may be very tight and need a bit of effort to get off.
- Udspie
Exhaust tips
Thanks for the info bud, I've had a go at removing one of them before but it's tight. I recon I'll wd40 them when the cars not in use and try again. Regards
Z4 23i Roadster
- Nictrix
Exhaust tips
I used a rubber mallet and trying to be careful got them off in the end.
At some point I want to get them plated as the original finish is pretty poor.
- Udspie
Exhaust tips
I think the originals are alloy...I've got a polishing kit that I use for the bike, a mirror finish on alloy is no problem (as long as you can get the feckin things off) LolNictrix wrote: ↑Fri Jun 16, 2017 8:00 pmI used a rubber mallet and trying to be careful got them off in the end.
Z4 23i Roadster
- Nictrix
Exhaust tips
Im not so sure they are alloy. They are held on with spring clips that are welded on and these rust onto the exhaust. That's what makes them so difficult to come off the first time.Udspie wrote: ↑Fri Jun 16, 2017 8:20 pmI think the originals are alloy...I've got a polishing kit that I use for the bike, a mirror finish on alloy is no problem (as long as you can get the feckin things off) Lol
- metal licker
Exhaust tips
Be gentle when polishing the tips they only have a thin coating over what looks like a copper base I found out the hard way
718 4.0 GTS Boxster in YELLOW
718 Guards Red Boxster .........Gone!
A35 AMG saloon .........Gone!
JCW ...........Gone !
E89 35i Msport VO ................Gone !
E89 23i SE DSB ................Gone !
Hello to Jason Isaacs
- Udspie
Exhaust tips
Must be a rivet/weld....The new genuine replacement ones are alloy. If they rust, they aint alloy, maybe not, I'm not 100% on that.Nictrix wrote: ↑Fri Jun 16, 2017 8:29 pmIm not so sure they are alloy. They are held on with spring clips that are welded on and these rust onto the exhaust. That's what makes them so difficult to come off the first time.
Possibly a seasoned owner may comment on this thread
Z4 23i Roadster
- metal licker
Exhaust tips
I sold these recently you can see the spring clips inside and as I said its a thin coating over a base metal
- Udspie
Exhaust tips
Not alloy then?...Poss mild steel...metal licker wrote: ↑Fri Jun 16, 2017 8:52 pm I sold these recently you can see the spring clips inside and as I said its a thin coating over a base metal
Z4 23i Roadster
- Deepseaskateboard
Exhaust tips
Mine are filthy also, the one part of the car I cannot get clean!
I purchased some silvio, and a buffing pad, not tried it yet....
Any advice on how to clean these would be much appreciated!!
- Nictrix
Exhaust tips
I use paraffin now and again just to get the worst off as they are never going to be spotless especially the ring at the end.
That's why I would like to plate ours.
Exhaust tips
They look like stainless with a dull chrome layer, usually decent chroming has a copper coat underneath.
- Nictrix
Exhaust tips
Would this mean it would be possible to polish right through both coatings into the stainless to get a good finish?
Exhaust tips
I think you will find spot weld blemishes if you remove the finish.
