Another Hunter alignment setup
StanM
Post by StanM » Thu Aug 31, 2017 2:30 pm
Ducklakeview wrote: Thu Aug 31, 2017 11:02 am A brief glance says you need MORE camber on the front, ideally as much as you can get, balanced evenly. Pull the camber pins. I'm running about -1.0 and it sharpened up the front end by a massive amount, toe is 0.07 per side, total of 0.14. At the rear I'm on camber -2.0 with a toe of 0.1 per side, total 0.2 which I'll possibly reduce to 0.1 per side once I fit the new rubber.
Yours is still out of spec, but the wrong spec. Mine has M sport suspension btw.
Mike
Thanks Mike,
I better check where that camber pin is on mine so I go there prepared. The Pro Tyres in Enfield didn't mention anything about camber pins and adding weights. Is this valid for the E89 as well as all the info I found online is referring to E85
2011 E89 sDrive23i M Sport Highline Edition, Alpine White, Coral Red Leather, 326M, Stubby
2004 E85 2.5i
2001 E46 320Ci
2000 E36/7 2.0i
Ducklakeview
Post by Ducklakeview » Thu Aug 31, 2017 2:42 pm
StanM wrote: Thu Aug 31, 2017 2:30 pm
Mike
Thanks Mike,
Sorry, didn't realise yours is an E89, however out of spec is still out!
Mine was weighed with I seem to remember 60kg on each seat and the same in the boot with a full tank of fuel.
Mike
AlienZed
Post by AlienZed » Thu Aug 31, 2017 3:52 pm
Interesting discussion.i'm currently sat in Infinity motors stockport having mine done.
Moz
hopz121
Post by hopz121 » Thu Aug 31, 2017 4:13 pm
The weight makes very little difference I have found.
Some people use it and some don't.
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
StanM
Post by StanM » Thu Aug 31, 2017 5:04 pm
hopz121 wrote: Thu Aug 31, 2017 4:13 pm The weight makes very little difference I have found.
Thanks mate, from various sources online I see that the change in car geometry with extra 150-200kg should be minimal as this is what the car is expected to carry any way (2 people + luggage + full tank) but again this still is extra weight that you put on the suspension and in theory it should have effect on the geometry as well.
2004 E85 2.5i
2001 E46 320Ci
2000 E36/7 2.0i
AlienZed
Post by AlienZed » Thu Aug 31, 2017 5:14 pm
Well here's mine .
Before.
After.
Couldnt get the front in green without taking out camber pin.
Rear camber in red as i didnt want loads od camber ont back .
hopz121
Post by hopz121 » Thu Aug 31, 2017 10:26 pm
Why didn't you take the camber pins out? Seems silly not too considering how easy it is to do
Rest if the adjustments seems ok and you did the right thing regarding the rear camber :thumbsup:
Bet it's driving better
AlienZed
Post by AlienZed » Fri Sep 01, 2017 8:35 am
Tbh they wouldnt do that .even with my permission.and as its only a wee bit out to the other side i aint too bothered.
The original readings were out coz ive changed all and i mean all ont suspension .steering etc.
Zed drives spot on again now so happy days.
M
StanM
Post by StanM » Fri Sep 01, 2017 10:32 am
Right, I found the camber pins.
Do I take them out before I go to the garage for alignment and leave them out after its done or do I have to put them back in.
2004 E85 2.5i
2001 E46 320Ci
2000 E36/7 2.0i
hopz121
Post by hopz121 » Fri Sep 01, 2017 11:22 am
StanM wrote: Fri Sep 01, 2017 10:32 am Right, I found the camber pins.
Take them out now, saves them trying to say they wont do it.
They are simple to remove :thumbsup:
AlienZed
Post by AlienZed » Fri Sep 01, 2017 11:32 am
Agree wi hopz.take em out :thumbsup:
Buckz
Post by Buckz » Fri Sep 01, 2017 11:43 am
I'd say MC autos in south London. I've had my Z4 there and they got both sides spot on. I'm sure they'll be happy to match what ever setup you give them. Or pull one from the database. Not BMW specialist per say but deal with some highly modded cars and had no issues installing my supplied parts etc
StanM
Post by StanM » Fri Sep 01, 2017 11:58 am
Ok, do I have to put the pins back in after they've aligned the camber?
Buckz, thanks mate I'll give them a call as well to check what they can do for me.
So at the moment I've got a few questions to ask the garages you suggested before I decide which one to try first (do they know about the camber pins, adding weight and custom alignment for better handling).
Looks like the last two I used are not the most knowledgable around (ProTyre in Enfield and A&S Tyres in South Woodford)
2004 E85 2.5i
2001 E46 320Ci
2000 E36/7 2.0i
brillomaster
Post by brillomaster » Fri Sep 01, 2017 1:04 pm
no, you don't need to put the pin back in. You'll see if you remove one of the 3 nuts holding the shocks in that the holes are slotted - the adjustment on front camber comes from sliding the top mount of the shock either inboard or outboard (most likely inboard for more negative camber). if the garage adjusts it at all, the pin wouldn't go back in anyways as it would be out of alignment.
hopz121
Post by hopz121 » Sat Sep 02, 2017 10:14 am
StanM wrote: Fri Sep 01, 2017 11:58 am Ok, do I have to put the pins back in after they've aligned the camber?
Nope leave them out :thumbsup:
