Hi all,
I thought I'd share my recent experience of the engine works I carried out over the past few months and to inform you of what to expect if you go down a similar route.
I bought my low mileage (28k) E85 M back in 2020 with the aim of modifying the engine to CSL+ specification. I took the car to my local respected rolling road (Maha/TAT) to do a power run in standard specification and it made a predictable 321.5 crank bhp; the rolling road chap said the power figure was totally expected in his experience with the S54s he had dyno'ed over the years.
Since buying the car I was lucky enough to acquire a set of Schrick 288/280 duration camshafts, Schrick finger rockers, Karbonius carbon fibre race spec airbox, ITG foam air filter, ARP head stud kit and full Supersprint exhaust including the 100 cpsi cats.
When installing all the parts I decided to remove the cylinder head and take it for Hack Engineering for inspection. Whilst there I was convinced to replace the valve guides for ones manufactured from a superior material and to a tighter tolerance. Also whilst the cylinder head was off I decided to 'bulletproof' the VANOS unit by fitting the uprated Viton seal kit and the uprated upper timing chain guide for Beisan Systems items.
Once the engine was fully rebuilt I reached out to Josh at Severn Tuning to provide the alpha-N ‘tune’ for the stock MSS70 ECU. I was very impressed with Josh and would recommend his services in a heartbeat, he is really knowledgeable about the MSS70 ECU and was super responsive in his approach with me. The 'tune' was developed from live on road data logging and a final dyno session.
So the results:
Before
Power 321.5 bhp @ 7999 r/min (239.74 kW)
Torque 253 lb/ft @ 5021 r/min (343.1 Nm)
After
Power 367.3 bhp @ 8015 r/min (273.9 kW)
Torque 257.6 lb/ft @ 6639 r/min (349.3 Nm)
An increase of almost 46 BHP at the top end and no noticeable losses down low in the rev range.
Hope that is useful info
So the results:
Before
After
