Brembo brakes on 3.0si coupe the easy way
[ref]Panta Rhei[/ref], so am I correct in saying that you have the set for the 3.0Si, but are running 345mm discs? No other changes, different brackets, etc?
Those photos are from Unit Racing fb - manufacturer of those adaprters.
Disc is from Z4M/M3 CSL 345x28, while standard M3 has got 325x28 (not 345x28 as many think).
Car on pics is non-M Z4. They have different adapters for Ms.
[ref]Panta Rhei[/ref], so am I correct in assuming you need the Unit Racing adapters to use the 345 discs? Or can you use the K-sport set and just slap on a set of 345’s?
Probably a question I know the answer to already, but rather make sure before biting the bullet :thumbsup:
Love the look on the car as well by the way!
I would msg guys from K-sport and ask them directly. Just to save time, nerves and $$ later. Measure twice cut once.
For example, maybe with K-sport adapter you will not have the required space to fit 245 as caliper would be closer to the center - too close, idk just assuming.
345 looks better with 19" also, not like Vauxhall astra 1.2 ecoboost brake disc from behind :cry:
marmite monster said:
K sport brackets only work with 325mm discs 100%
Thanks for that! :thumbsup:
So then: callipers from K-sport, brackets from Unit Racing (or do they sell the calliper/bracket combination as a set as well?), discs from an M3CSL. Thanks for all the info, defo the way forward 8)
Slight tangent here, but the Porsche Boxster S callipers are also a good upgrade, and can be used with 325m discs if the calliper has 10mm shaved off, or are a direct fit (with proper brackets) for the 345 CSL/Z4M discs
Here’s mine
