Dash cam
Chippie
Wakefield
A little advice please
Considering a dash cam for the Zed,
Blackvue DR750S-2CH (16GB) Front & Rear Dash Cam Wi-Fi GPS Full HD
I take it this has 2 separate cameras, has anyone any recommendations for fitting the rear view camera (position)
Or is there a dash cam that mounts to the rear view mirror/windscreen that views front and rear in one unit
Any other recommendations?
Cheers Mick
I’m thinking about one too. I want rear view more for when it’s parked up and the one BMW have offered to fit says front only.
I’m sure one of the blackvue ones has both in a cylindrical shape that has a front and rear facing camera in the one unit that attaches to the windscreen. What I’m also sure I read, but can’t for the life of me find it again, was that in the E89 because it’s so tight at the back the rear had a very limited view and also if you left the wind deflector in it was even worse, to the point of useless.
The G29 has an even smaller rear view, I asked about getting the rear camera on the roll hoops and tbf, they said possibly but they wouldn’t do it incase it looks untidy/awful so I’ve sort of discounted and am looking at a Garmin W65 front facing only.
I’ll be watching your thread with interest to see if I can get any ideas :thumbsup:
I had also considered a dashcam & was looking at this model
I have YouTube’d it to check real life reviews plus video footage
I’m umming & ahhring because I don’t know how obtrusive they are on the front windscreen plus I’d want it wired in & I have no idea how expensive that would be to get fitted
https://www.amazon.co.uk/AQP-3840x2...lectronics&sprefix=Aqp,electronics,165&sr=1-4
I’m also following this thread with interest & I'm based in Sutton Coldfield West Midlands if anyone can recommend a fitter
I fit a Nextbase to my Audi a few years ago before the market was flooded with higher end brands, good quality playback and no issues with it whatsoever, I've recently fitted in in my E89, didn't want the fuss or untidyness of wiring a rear view so just bought hardwire kit and in it went.
As a compromise, I've just fitted a Nextbase 322GW with cabin view to my Dads VW Tiguan. It's not perfect on the rear view aspect but Im confident in the event of an accident it will be adequate to determine who's at fault.
It might not be as wizzy as seome of the expensive brands but it really does take a good 1080p recording and includes software for playback with GPS location speed and everything you might want to delete is required :tumbleweed:
Sure there will be a few youtube clips showing what recordings are like if you fancy going that way.
I have a nextbase 522GW with the plug in rear view module.
Gives great footage - when it works.
Its actually my third camera the first one got so hot it was a serious fire risk, when i took it back to Halfords to complain the guy said "really, lets have a look" then he went to grab it and then he said "s**t" - that hot!!!
Second one just locked up all the time, especially if park mode enabled, nextbase gave metheri top size memory card and another camera.
This ones ok but by no means reliable.
On the subject of memory cards in dash cams - the architecture of an off the shelf SD Card does not like repeated writing/erasing. The NextBase cards apparently have a different build, which accounts for the cost...
I once had a blackvue front and rear dashcam can’t remember the model but iirc it cost in the region of £170 had lots of problems with it locking up eventually gave up with it and went for a nextbase 400 front view only and it has been working great for a couple of years reasonably cheap as well. The only problem I have had is with the memory cards you definitely need a quality make.
Martin, these people have had quite a few recommendations on here. I see they also do a price match and fit at work or home :thumbsup:
https://www.avrmobiles.co.uk/acatalog/terms_conditions.html
Just googled that about getting hot, seems to be more common with the newer / higher end Nextbase cameras, my older 312GW doesn't get hot, my dad hasn't mentioned his 322GW getting hot either though.
As for memery cards, I've used a Kingston 32GB with mine, same card for years, I've probably reformatted a hand full of times max.
After looking at reviews on here I went for a A129 Pro Dual Dash Cam with a Front & Rear camera. Its not cheap though if you go for the hi res one. I got mine from https://viofouk.co.uk/. the front camera fits nicely behind the mirror, and the rear I have put into the passenger roll bar hoop on a custom cradle I made. I had to remove the mesh (although its hardly noticeable), and run the cable under the plastic cover. It doesn't appear to make it more windy for the passenger.. As normal, the worst part is getting to the fuse box.. and struggling with the concertina design..
I’m interested in what people have done to mount the cams as well
A lot of people I know who own them have theirs suctioned cupped to the windshield but I like the idea of ‘hiding’ it behind the rear view mirror if this is an option which is why I liked the look of that Amazon one I posted above as I figured you could hide it & it didn’t look too big
this is mine, I dont even know its there except for the funny noise it makes on startup/shutdown...
Can only comment on the one I got my Dad about 3 or 4 years ago,a Nextbase front only one,and its been perfectly reliable, as he uses it every time he is out in his car.
It never gets hot or has any issues with locking up/freezing or parking mode.
I have the same as Clarker63 and have nothing but positive feedback for it, mine was the A129 dashcam front and back. Running the cables yourself isn't too difficult. I mounted the rear dashcam upside down to make fitment easier, and there is a handy tool in the VIOFO app allowing you to flip the image for playback.
My front camera is hidden on the passenger side behind the rear-view mirror, don't even notice its there (startup jingle turned off in the app). With regard to hiding the dashcam, someone mentioned adding some black vinyl near the rear-view mirror to mask the suction in a previous thread. Just search 'vinyl dashcam' and I'm sure it will come up.
I have some decent footage keeping an Aston Martin DB11 honest somewhere. I just need to figure out how to upload it now.
Other useful threads:
https://z4-forum.com/forum/viewtopic.php?f=23&t=109239
https://z4-forum.com/forum/viewtopic.php?f=46&t=111268
I’ve just fitted the dash cam below, seems good and a small size so looks good and seems to work well
https://www.amazon.co.uk/gp/product/B07W3TGSC9/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
I have a DR750S 2CH and the front is stuck to the left of the rear-view mirror. The rear is stuck right in the top centre of the wind deflector. Has been installed for 2 years now and has never budged.
Felix, do you have any pictures of the rear one fitted. Still in discussions with bmw about fitting a rear one :thumbsup:
I’ve been looking at that, Halfords had it on offer for £350 (if I remember correctly) but it’s currently out of stock, they have the DR750X 2ch also on offer at £303 which I was thinking of buying, I was wondering if the rear one would sit on the shelf behind the roll hoops or would it be too low?
Edit
The DR750s 2ch was £250 not £350
Mick, the BMW dealer sent me this yesterday for rear mounting to see if I was happy if it looked like this but their master tech wasn’t as he said it was too untidy with the wires showing and they wouldn’t let it out the workshop like that on a brand new car so therefore won’t fit it :headbang:
