X-S-Z said:cj10jeeper I think you need to post some photos of the car outside in the dark.... I am curious to see the full effect of these mods...
Good point - never got around to doing it. Will try one evening
acerboo said:hi i notice you have the z4 illuminated door plates are they difficult to fit and wire thanks
pvr said:Although, I seem to be missing the mirror light like we have in the X5![]()
ROZ said:Jeepers,
I am so looking forward to Spring and taking your lead.
Do you think the 5mm LEDs are OK? I was just considering 3mm instead; the output of these goes up and up as time goes by so no issue with light levels, but the 3s might be less conspicuous and easier to install??
ROZ said:So looking at it all, I don't have any footwell lights, so the only dimming light I have is the main one. Jeepers, do you know what connection number it was you picked up from? I'm assuming that the loom is all in there, and only the lights themselves are omitted depending on the originally requested specification. Got to love BMW and there "bare bones plus options" policy 8)
Baracus (aka Steve) said:the puddle lights and ext door handle lights are exactly what i already have planned myself, great write up. would be pretty cool if you could list and link exactly what you used and where they where purchased
Brilliant, i'll be following this writeup myself very soon
Also, the illuminated kick plates are very nice and i've seen some for sale for very silly money, can they be bought elsewhere at a reasonable price do you know?
Baracus (aka Steve) said:I already have quite alot of strip lighting which i had given me from a job i did not to long ago so i was goin to use them for the puddle lights and thought about a strip under the door handles so i'm unsure which way to do it now i've seen yours. The main ones i want are the ext door handles but while i'm there i may as well do the puddle lights too![]()
cj10jeeper said:Baracus (aka Steve) said:I already have quite alot of strip lighting which i had given me from a job i did not to long ago so i was goin to use them for the puddle lights and thought about a strip under the door handles so i'm unsure which way to do it now i've seen yours. The main ones i want are the ext door handles but while i'm there i may as well do the puddle lights too![]()
Don't use strip under the door handles else I'm sure fingers will cause them to come off, or washing and the power cable will have to go outside. I simply bonded the tip of an LED through and exact sized hole and worked perfectly ever since
