Sport button??? As mentioned above, does it work?Brownie said:Because the steering motor has failed it does not show anything when scanning .
Ok so usually with the sport button not working either it is definitely the eps ecu. Sounds like yours has an issue with a dodgy connection inside that needs to warm up. It will only get worse. I suggest you contact ECUTesting to see if they can help.Brownie said:When I tstart the car after it has not been used for a few days the steering is stiff and the Sport button light is off. After driving for a couple of kilometres the steering frees up and the Sport light comes on.
The process repeats when I stop and turn off the key.
Cheers. I was just searching for thatraymond.harper said:https://www.ecutesting.com/product-catalogue/bmw/z4/power-steering-eps-electric-power-steering/
